I have a large historical database, all with different projections and areal
coverage . . . but consistent enough that I am writing a script to suck this
data into grass.
I have hit a snag, however, in being able to automate the database creation.
For instance, I have written the script to use a "dumby" database to start up
enough to do a "v.in.sdts catd=<my sdts catalog> -i" and redirect so I can
parse out the edges, UTM zone, and name.
Then, I try "grass5 /data/gis/my_files/borders/<NEW_NAME>/PERMANENT
where "borders" is my GISDBASE. "<NEW_NAME>/PERMANENT" is the new area for
storage desired, and I had hoped that grass would prompt me like it does in
interactive mode, to create a new area. But it won't - just gives me:
Not a valid GRASS location
Is there a way to script the creation of a database?
Stonie R. Cooper
Planetary Data, Incorporated
(402) 782-6611
data into grass.
Only by manually creating the directories and essential files. E.g.
#!/bin/sh
base=/data/gis/my_files/borders
loc=<NEW_NAME>
mkdir $base/$loc
mkdir $base/$loc/PERMANENT
cp $base/dummy/PERMANENT/DEFAULT_WIND $base/$loc/PERMANENT
mkdir $base/$loc/mymapset
cp $base/$loc/PERMANENT/DEFAULT_WIND $base/$loc/mymapset/WIND
grass5 $base/$loc/mymapset
data into grass.
I have written such script for raster data (needs r.in.gdal working):
http://mpa.itc.it/grasstutor/examples.phtml
-> create_location.sh
Maybe it helps.
Later, after v.in.ogr is extended to generate new locations, we
could provide the same for vector data.
