[GRASSLIST:10441] connect with selection???
Hello,
currently I keep in a pg table X,Y,value,type,date of meteostation and import the rain vector with:
echo "SELECT x,y,value FROM observation where type=rain and date='200602101200'" | db.select -c | v.in.ascii out=rain.200602101200
Conceptually the geometry is static and just the attribute are time dependent.
So I wonder if is there a way for select vector attributes based on WHERE statement?
What I need should be a sort of v.db.connect with table="SELECT bla bla FROM bla bla WHERE bla bla"...
Do you have some hints for doing the rigth thing?
Massimiliano
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
On Monday 20 February 2006 09:45 am, Massimiliano Cannata wrote:
Hello,
dependent.
WHERE statement?
Massimiliano
I wonder if the GRASS PG driver support views? -- this would be exactly what
you are asking for i think.
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
