I have been a command-line bigot forever, and rarely use the d.m or gis.m
features of GRASS --- I once tried gis.m and liked what I saw, but don't
use it routinely, and indeed haven't tried it in a few weeks. As for
d.m, my first command on starting GRASS is typically "File->Exit" in d.m.
After all this talk of revamping GRASS so that the X displays can go away, I
decided to try out gis.m again lest I fall so far behind the times that
GRASS becomes unusable for me overnight. Using grass-6.1 cvs updated last
night, I get:
gis.m
Error in startup script: bad event type or keysym "ConfigureRequest"
while executing
"bind .mapcan($mon) <ConfigureRequest> {
set wstack %d
puts "stack is $wstack"
puts "mouse click $mon"
(procedure "MapCanvas::create" line 117)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 96)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 777)
Any hints on where to look for what's wrong here? Could this be a tcl/tk
versioning issue? (I'm using tcl/tk 8.3, although I do have tcl 8.4 installed
--- just not set up so that configure finds it, coz once upon a time 8.4 was
unusable with grass.)
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit." --- The Tick
On Mon, Feb 20, 2006 at 06:25:45PM -0700, we recorded a bogon-computron collision of the <russo@bogodyn.org> flavor, containing:
night, I get:
> gis.m
while executing
Google to the rescue. Yes, ConfigureRequest is something that is only present
in tcl 8.4.
If this incompatibility with tcl/tk 8.3 is necessary for proper function of
gis.m, the various install documents should ultimately be updated, and
perhaps configure should not accept tcl/tk 8.3 anymore.
Re-adjusting my tcl/tk 8.3 vs. 8.4 install and letting grass use 8.4 fixed
gis.m.
On Mon, 20 Feb 2006 18:39:56 -0700
Tom Russo <russo@bogodyn.org> wrote:
> > gis.m
> while executing
> tcl/tk versioning issue? (I'm using tcl/tk 8.3, although I do have
> tcl 8.4 installed --- just not set up so that configure finds it,
> coz once upon a time 8.4 was unusable with grass.)
I confirm - until today I could start gis.m, now I can't. I'm on Ubuntu
thus using tcl/tk 8.3 due to 8.4 doesn't work with NVIZ. Will I have to
install 8.4 and fiddle around with it to make gis.m work?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Maciek Sieczka wrote:
> > > gis.m
> > while executing
No. gis.m shouldn't be binding ConfigureRequest in the first place, as
it will never receive this event. Just delete the corresponding "bind"
command from the gis.m source.
[The only way that a Tk application can receive ConfigureRequest
events is if it uses C code to add the SubstructureRedirectMask bit to
a window's event mask.]
