[GRASSLIST:10520]
Is there a way to specify the layer (table) that comes up to
interactively edit attributes in d.what.vect? In my case I have 2
layers (ie tables) associated with a particular vector map. If I
display the vector map with d.vect 'map_name' then run d.what.vect -e,
the form that comes up only has the first layer (table) in it. I
would like to edit layer 2, by clicking on the polygon in the vector
map.
Is that possible?
Kirk
In the new GIS Manager, the display data button will now *display* data for
whatever layer you specify in the vector panel. Unfortunately, it still will
not let you *edit* the data.
Note: if there is some industrious person out there that really wants a data
editor and the undying gratitude of the GRASS user community, it should be
possible to write one using existing GRASS db.* commands and TclTk. There
are also some TclTk libraries--not currently required for GRASS--that
support table creation and management (tablelist) and SQLite.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 22 Feb 2006 08:32:02 -0600
To: <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:10520]
map.
Is that possible?
Kirk
map.
Is that possible?
If you have 2 layers they should appear in 2 attribute tabs.
I guess that you dont have categories of the second layer assigned to
features in the map.
v.category option=report?
Radim
Kirk
