[GRASSLIST:1055] RE: srtm
Hi all, thanks for the suggestions. I haven't tried them all, but they were all
helpful for understanding how to do this stuff. The one I finally used with
incredible ease was a simple r.mapcalc using gtopo30 data.
r.mapcalc newmap=if(isnull(gtopo30), gtopo30, srtm)
Thanks, Ian
I thought of the same strategy but using GLOBE. But then I thought that many hole HAVE information in the neighbouring cells in STRM, and that for small holes using just GLOBE would be loosing too much info, since the res for STRM is much better. So I planned (haven't using it, for the unrelated problems I related of before),
if null:
  average of ((sum of neighbours at STRM) + GLOBE)
I don't recall the correct syntax for mapcalc, but you get the idea. It will make an average of all non-null values in SRTM plus the one GLOBE value. So the data is self-weighted: if the hole is big, GLOBE takes more weight, if its small, then the higher-res SRTM takes more weight.
What do you people think?
-Gustavo
