Hi, i used r.in.srtm for building a DEM. I have joined images (1°x1° squares) using r.patch, and now i'm trying to fill "no data" holes in the map i obtained. I think to use r.fillnulls, but have the following error:
r.fillnulls input=input_name output=srilanka.dem tension=40. smooth=0.1
Using tmp file r_fillnulls_3464
Locating and isolating NULL areas...
GRASS_INFO_ERROR(3474,1): invalid ellipsoid i
\a in file PROJ_INFO in PERMANENT
GRASS_INFO_ERROR(3479,1): invalid ellipsoid i
expr: errore di sintassi
invalid ellipsoid i
ERROR detected: /usr/lib/grass/scripts/r.fillnulls abandoned. Removing temporary map:
REMOVE [r_fillnulls_3464]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
ERROR: <mask_3464> not found
what have i to do?
Many thanks,
Antonio Giglio.
________________________________________________________________________
Offro&Cerco: CASA, LAVORO, VACANZE, ELETTRONICA, INCONTRI. Tutti gli
annunci sono online su Kataweb all'indirizzo http://www.offroecerco.it
On Fri, 24 Feb 2006 16:28:02 +0000
following error:
smooth=0.1 Using tmp file r_fillnulls_3464
Please post what Grass version you are using, g.proj -p output and the
contents of your_location/PERMANENT/PROJ_INFO file. Maybe it will help
to indicate the problem.
<snip>
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Da: Maciek Sieczka <werchowyna@epf.pl>
Data: Sat, 25 Feb 2006 09:46:03 +0100
A: "giglio.antonio@katamail.com" <giglio.antonio@katamail.com>
Oggetto: [GRASSLIST:10565] Re: r.fillnulls
> following error:
<snip>
Maciek
first of all thank you for the reply!...than here are the informations you ask me for:
- i'm using versions 6.0.1 and 6.1cvs (updated today), both with the same problem;
- g.proj -p output is:
-PROJ_INFO-------------------------------------------------
proj : ll
ellps : i
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
-PROJ_INFO file contents:
proj: ll
ellps: i
a
i have the same problem also using v.in.ogr
SERVIZIO VOICE: TELEFONA e INVIA SMS dal tuo computer a tariffe vantaggiose!
Scopri come telefonare e videochiamare gratis da pc a pc.
http://voice.repubblica.it
following error:
<snip>
Maciek
proj : ll
ellps : i
unit : degree
units : degrees
meters : 1.0
proj: ll
ellps: i
a
The ellipsoid was apparently defined incorrectly.
To fix the problem, you can either use g.setproj to redefine the
same projection (here: latlong) or edit the PROJ_INFO file
in the mapset PERMANENT.
> following error:
As the message says: an ellipsoid "i" doesn't exist.
This needs to be defined properly.
