[GRASSLIST:10560] Re: TOPIDX flow direction algorithm
Thanks. I'll check it out.
T
----- Original Message Follows -----
To: twiens@interbaun.com
Cc: GRASSLIST@baylor.edu, grass4u@gmail.com
Subject: [GRASSLIST:10558] Re: TOPIDX flow direction
algorithm
Date: Fri, 24 Feb 2006 10:44:30 -0800
I would highly recommend enabling c++ support when you
compile GRASS, so that you have access to the r.terraflow
This will compute a TCI, and in many cases I have found
the output from r.terraflow to be superior to the
analogous commands in GRASS.
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
