[GRASSLIST:10574] Re: Labels and ps.map
Hi Nick,
and ps.map has to rely on the - I assume, somewhat outdated - method
of using a separate label file? Currently, to get labels to come out
correctly in ps.map, I have to run ps.map, look at the postscript
output, find that the labels are a bit too big or something, make a
whole new label file with different parameters, and start again; and
this usually takes a number of iterations.
v.label + friends are your best bet.
v.label works quite well for creating & customizing labels:
  http://grass.itc.it/grass61/manuals/html61_user/v.label.html
This creates a labels text file which you can tweak with any text editor.
e.g. font size based on city population:
v.extract where="pop>100000" out=city
v.label city fontsize=14
v.extract where="pop>100000" out=town
v.label city fontsize=10
then cat both label files together or use two display commands in series.
or trade v.extract for 'grep -A'
d.labels (nee d.site.labels) works quite well for displaying them*, although
note that placement is slightly different between d.labels and ps.map's labels
command- offset is in screen pixels not PostScript units (aka points or 1/72"
on the page). Results are similar though. Do modify the offset values, not the
northing and easting.
[*] have labels file open in another window, tweak&save, then d.redraw
that should get you close so when you use ps.map's "labels" instruction the
results should be nearly perfect.
All these commands are updated and working well in GRASS 6.1 (AFAICT), and are
all somewhat flaky in GRASS 6.0. I'll try and fix any remaining bugs you find
in the devel version, but probably not quickly as while I'm back on dry land
now I'm still away from the office for a wee while more.
As v.label's long option list shows, there are too many controls (IMO) to
simply add all that functionality to the ps.map vpoints instruction set.
regards,
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
