[GRASSLIST:1058] ellipsoid
I need to define a location using a county-wide version of LCC given ellipsoid semi-major/minor axes. I appended the available ellipsoid information to \gdal\ellipsoid.csv, but it did not show up as an option when I listed the available ellipsoids. Do other files need to be edited (\gdal\gdal_datum.csv) ?
Using Cygwin\Grass6.0...
Thanks.
Martin
Martin du Saire wrote:
Thanks.
Martin,
you could try to add it instead to
lib/gis/ellipse.table
Modifying the csv files is probably much more complex and should be done
in GDAL (where
we get these files from).
