Grass users....
I have to create the most parsimonious
species range polygon out of sites where the species have beeen
observed/sensed and thought that s.geom w/ the delaunay option will do
it.
Whenever run the program with precision > 0 I get the following error:
GRASS:~ > s.geom input=WPHantaOct output=HAntaDEL2 precision=1
operation=delaunay
Reading sites map (WPHantaOct) ...
Found 38 sites ...
SoS: matrix[38,5] @ 8 Lia digits; lia_length (16); 0.008 Mb.
Removing duplicate vertices ...
siMarkDeletedDuplicates: 15 duplicate sites marked.
NOTE: long integer coordinates used for comparison. due to roundoff
two sites may have identical coordinates, although in the
input data they don't.
siRemoveDuplicates: 15 duplicate sites removed.
Plane Sweep: completed, cpu used 0.000000.
Lawson Flip: quInsert: SORRY, I'M FULL.
I checked the memory of the machine and it seems to have plenty of
space... plus I'm using only 38 sites!! Could someone tell me what I'm
doing wrong? It looks like it is doing the calculations but can't write
the output to the disk!
I will appreciate your help,
Best regards,
thanks.
horacio
Horacio Samaniego
Dep. Ecologia
P. Universidad Catolica
Alameda 340
Santiago, Chile
Fono: (56 2)686 2950
Fax: (56 2)686 2621
Email: hsamanie@bio.puc.cl
