[GRASSLIST:10625] Re: problems with GIS manager Re: GRASS 6.1 c vs gis.m error
Patton, Eric wrote:
A similar message is produced for every other monitor. I also noticed
that
in the Feb.25th Grass 6.1 binary, there is no monitorcap file in
$GISBASE/etc. I believe there used to a be a monitorcap file here a
few
weeks ago, because I remember having to remove/overwrite it with the
one
from the gis.m tarfile. Is this normal?
No. Do either driver/PNG or driver/XDRIVER exist?
Aha. No, driver/PNG and driver/XDRIVER don't exist. So somehow support for
these drivers was excluded recently from the generic linux binaries? Is it a
simple task to get support built back in?
~ Eric.
Patton, Eric wrote:
> > A similar message is produced for every other monitor. I also noticed that
> > $GISBASE/etc. I believe there used to a be a monitorcap file here a few
> > weeks ago, because I remember having to remove/overwrite it with the one
I would guess that compilation simply failed for some reason. I don't
know if the build process for the snapshots keeps logs which would
indicate why, or if that even matters now.
Obviously, if the problem recurs, that indicates an outstanding bug
which needs to be fixed. Right now, it's probably more important to
figure out what to do if we end up with a weekly snapshot which is
substantially broken (like the Feb 25 one).
As it stands, the choice is between 6.0.2, a snapshot which is
essentially useless, waiting nearly a week for the next snapshot, or
learning to build GRASS from source (non-trivial, given the number of
dependencies).
I would suggest that we should keep at least one previous snapshot
around in case of situations like this. I would also suggest replacing
the current snapshot with a new version, rather than waiting until
next week.
Amusingly, I am currently working on this in grass.itc.it :slight_smile:
So:
cat error.log
GRASS GIS compilation log
Started compilation: Tue Feb 28 23:35:01 CET 2006
Errors in:
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/PNG
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER
That's why monitorcap is missing.
dependencies).
Why not simply bothering the maintainer of grass.itc.it (still a
Redhat 7.3 box)?
Here we are:
bash-2.04$ cd display/drivers/XDRIVER
bash-2.04$ make
gcc -Wl,--export-dynamic -L/usr/local/lib -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -Wl,-rpath-link,/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -o /hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/driver/XDRIVER -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib OBJ.i686-pc-linux-gnu/Box.o OBJ.i686-pc-linux-gnu/Can_do.o OBJ.i686-pc-linux-gnu/Client.o OBJ.i686-pc-linux-gnu/Color_table.o OBJ.i686-pc-linux-gnu/Color.o OBJ.i686-pc-linux-gnu/Draw_bitmap.o OBJ.i686-pc-linux-gnu/Draw_line.o OBJ.i686-pc-linux-gnu/Draw_point.o OBJ.i686-pc-linux-gnu/Get_w_box.o OBJ.i686-pc-linux-gnu/Get_w_line.o OBJ.i686-pc-linux-gnu/Get_w_pointer.o OBJ.i686-pc-linux-gnu/Graph_close.o OBJ.i686-pc-linux-gnu/Graph_set.o OBJ.i686-pc-linux-gnu/Line_width.o OBJ.i686-pc-linux-gnu/Panel.o OBJ.i686-pc-linux-gnu/Polydots.o OBJ.i686-pc-linux-gnu/Polygon.o OBJ.i686-pc-linux-gnu/Polylin!
e.o OBJ.i686-pc-linux-gnu/Raster.o OBJ.i686-pc-linux-gnu/Raster_RGB.o OBJ.i686-pc-linux-gnu/Respond.o OBJ.i686-pc-linux-gnu/Serve_Xevent.o OBJ.i686-pc-linux-gnu/Work.o OBJ.i686-pc-linux-gnu/alloc.o OBJ.i686-pc-linux-gnu/main.o -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lfreetype -L/usr/X11R6/lib -lSM -lICE -lX11 -lm -lz
/usr/local/lib/libgrass_driver.a(main.o): In function `main':
main.o(.text+0x40): multiple definition of `main'
OBJ.i686-pc-linux-gnu/main.o:/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/main.c:6: first defined here
/usr/bin/ld: Warning: size of symbol `main' changed from 301 to 956 in main.o
OBJ.i686-pc-linux-gnu/Color_table.o: In function `init_color_table':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:302: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:302: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:303: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:303: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:304: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:304: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:305: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:305: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:306: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:306: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:307: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:307: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:308: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:308: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:309: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:309: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:310: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:310: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:311: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:311: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:312: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:312: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:313: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:313: undefined reference to `LIB_assign_standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:314: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:314: undefined reference to `LIB_assign_standard_color'
OBJ.i686-pc-linux-gnu/Color_table.o: In function `XD_Color_table_float':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:374: undefined reference to `COM_Can_do_float'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:384: undefined reference to `COM_Color_offset'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:386: undefined reference to `DRV_reset_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:387: undefined reference to `DRV_reset_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:388: undefined reference to `DRV_reset_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:389: undefined reference to `DRV_reset_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:390: undefined reference to `DRV_reset_color'
OBJ.i686-pc-linux-gnu/Color_table.o:/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:391: more undefined references to `DRV_reset_color' follow
OBJ.i686-pc-linux-gnu/Color_table.o: In function `XD_Color_table_fixed':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:408: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:408: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:409: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:409: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:410: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:410: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:411: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:411: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:412: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:412: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:413: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:413: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:414: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:414: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:415: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:415: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:416: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:416: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:417: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:417: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:418: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:418: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:419: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:419: undefined reference to `LIB_assign_fixed_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:420: undefined reference to `DRV_lookup_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color_table.c:420: undefined reference to `LIB_assign_fixed_color'
OBJ.i686-pc-linux-gnu/Color.o: In function `XD_color':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Color.c:25: undefined reference to `DRV_get_table_type'
OBJ.i686-pc-linux-gnu/Graph_set.o: In function `sigint':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Graph_set.c:96: undefined reference to `COM_Graph_close'
OBJ.i686-pc-linux-gnu/Graph_set.o: In function `XD_Graph_set':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Graph_set.c:346: undefined reference to `COM_Can_do_float'
OBJ.i686-pc-linux-gnu/Raster.o: In function `XD_Raster_int':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Raster.c:90: undefined reference to `LIB_get_color_index_array'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Raster.c:94: undefined reference to `DRV_get_table_type'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Raster.c:141: undefined reference to `LIB_get_color_index'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Raster.c:144: undefined reference to `DRV_get_table_type'
OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `get_xevent':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Serve_Xevent.c:29: undefined reference to `LIB_command_get_input'
OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `service_xevent':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Serve_Xevent.c:82: undefined reference to `COM_Graph_close'
OBJ.i686-pc-linux-gnu/Serve_Xevent.o: In function `handle_resize_event':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Serve_Xevent.c:267: undefined reference to `COM_Standard_color'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Serve_Xevent.c:268: undefined reference to `COM_Erase'
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/Serve_Xevent.c:286: undefined reference to `COM_Set_window'
OBJ.i686-pc-linux-gnu/main.o: In function `main':
/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/display/drivers/XDRIVER/main.c:46: undefined reference to `LIB_main'
/usr/local/lib/libgrass_driver.a(main.o): In function `handle_sigterm':
main.o(.text+0x36): undefined reference to `Graph_Close'
main.o(.text+0x1d9): undefined reference to `Graph_Set'
/usr/local/lib/libgrass_driver.a(Clr_table.o): In function `Color_table_float':
Clr_table.o(.text+0x12): undefined reference to `can_do_float'
Clr_table.o(.text+0x4e): undefined reference to `reset_color'
Clr_table.o(.text+0x65): undefined reference to `reset_color'
Clr_table.o(.text+0x95): undefined reference to `reset_color'
Clr_table.o(.text+0xa8): undefined reference to `reset_color'
Clr_table.o(.text+0xbb): undefined reference to `reset_color'
/usr/local/lib/libgrass_driver.a(Clr_table.o)(.text+0xce): more undefined references to `reset_color' follow
/usr/local/lib/libgrass_driver.a(Color.o): In function `Color':
Color.o(.text+0x20): undefined reference to `color'
/usr/local/lib/libgrass_driver.a(Color.o): In function `RGB_color':
Color.o(.text+0x59): undefined reference to `color'
/usr/local/lib/libgrass_driver.a(Color.o): In function `Standard_color':
Color.o(.text+0x1d5): undefined reference to `color'
/usr/local/lib/libgrass_driver.a(command.o): In function `process_command':
command.o(.text+0x3b2): undefined reference to `line_width'
command.o(.text+0x5e9): undefined reference to `Get_location_with_box2'
command.o(.text+0x62e): undefined reference to `Get_location_with_box2'
command.o(.text+0x705): undefined reference to `Get_location_with_line2'
command.o(.text+0x74a): undefined reference to `Get_location_with_line2'
command.o(.text+0x7f8): undefined reference to `Get_location_with_pointer2'
command.o(.text+0x835): undefined reference to `Get_location_with_pointer2'
command.o(.text+0x87d): undefined reference to `Graph_Close'
command.o(.text+0xe2e): undefined reference to `Polygon_abs'
command.o(.text+0x17c1): undefined reference to `Panel_save'
command.o(.text+0x1801): undefined reference to `Panel_restore'
command.o(.text+0x183d): undefined reference to `Panel_delete'
command.o(.text+0x1d5d): undefined reference to `Get_location_with_box2'
command.o(.text+0x1d75): undefined reference to `Get_location_with_line2'
command.o(.text+0x1d8c): undefined reference to `Get_location_with_pointer2'
/usr/local/lib/libgrass_driver.a(connect_sock.o): In function `get_connection_sock':
connect_sock.o(.text+0x10a): undefined reference to `Graph_Close'
/usr/local/lib/libgrass_driver.a(Box_abs.o): In function `Box_abs':
Box_abs.o(.text+0x68): undefined reference to `Polygon_abs'
/usr/local/lib/libgrass_driver.a(Cont_abs.o): In function `Cont_abs':
Cont_abs.o(.text+0x2c): undefined reference to `draw_line'
/usr/local/lib/libgrass_driver.a(Polygn_rel.o): In function `Polygon_rel':
Polygn_rel.o(.text+0x5b): undefined reference to `Polygon_abs'
/usr/local/lib/libgrass_driver.a(Raster_def.o): In function `Raster_int_def':
Raster_def.o(.text+0x26): undefined reference to `color'
/usr/local/lib/libgrass_driver.a(Reset_clrs.o): In function `_float_Reset_color':
Reset_clrs.o(.text+0x1eb): undefined reference to `reset_color'
/usr/local/lib/libgrass_driver.a(Text3.o): In function `draw_bitmap':
Text3.o(.text+0x4f0): undefined reference to `draw_point'
collect2: ld returned 1 exit status
make: *** [/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/driver/XDRIVER] Error 1
The PNG driver shows very similar problems. I can post that on
demand as well.
So:
cat error.log
Errors in:
And if it was present, it wouldn't be much use.
> dependencies).
Redhat 7.3 box)?
Here we are:
bash-2.04$ make
gcc -Wl,--export-dynamic -L/usr/local/lib -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -Wl,-rpath-link,/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -o /hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/driver/XDRIVER -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib OBJ.i686-pc-linux-gnu/Box.o OBJ.i686-pc-linux-gnu/Can_do.o OBJ.i686-pc-linux-gnu/Client.o OBJ.i686-pc-linux-gnu/Color_table.o OBJ.i686-pc-linux-gnu/Color.o OBJ.i686-pc-linux-gnu/Draw_bitmap.o OBJ.i686-pc-linux-gnu/Draw_line.o OBJ.i686-pc-linux-gnu/Draw_point.o OBJ.i686-pc-linux-gnu/Get_w_box.o OBJ.i686-pc-linux-gnu/Get_w_line.o OBJ.i686-pc-linux-gnu/Get_w_pointer.o OBJ.i686-pc-linux-gnu/Graph_close.o OBJ.i686-pc-linux-gnu/Graph_set.o OBJ.i686-pc-linux-gnu/Line_width.o OBJ.i686-pc-linux-gnu/Panel.o OBJ.i686-pc-linux-gnu/Polydots.o OBJ.i686-pc-linux-gnu/Polygon.o OBJ.i686-pc-linux-gnu/Polyl!
in!
It's using the version in /usr/local/lib rather than in the build
tree. That's because -L/usr/local/lib comes first. Doesn't the linker
look there automatically? If it doesn't, don't use
--with-libs=/usr/local/lib when configuring.
In any case, the definition of LDFLAGS in Grass.make.in should
probably be changed from:
  LDFLAGS = $(LINK_FLAGS) $(LIBPATH) $(LD_SEARCH_FLAGS) $(PQLIBPATH) $(USE_TERMIO)
to:
  LDFLAGS = $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH) $(USE_TERMIO)
so that the GRASS build tree is searched before system directories.
These are all symptoms of using the wrong version of libgrass_driver.
If possible, remove the GRASS libraries from /usr/local/lib (similarly
for include, bin etc). Having them there could mask problems with the
build. If a library fails to build, anything which depends upon it
should fail to build, rather than using an installed version of the
library.
> So:
> cat error.log
> Errors in:
> > dependencies).
> Redhat 7.3 box)?
> Here we are:
> bash-2.04$ make
> gcc -Wl,--export-dynamic -L/usr/local/lib -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -Wl,-rpath-link,/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib -o /hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/driver/XDRIVER -L/hardmnt/grass0/neteler/grass61_cvs_pserver/grass6/dist.i686-pc-linux-gnu/lib OBJ.i686-pc-linux-gnu/Box.o OBJ.i686-pc-linux-gnu/Can_do.o OBJ.i686-pc-linux-gnu/Client.o OBJ.i686-pc-linux-gnu/Color_table.o OBJ.i686-pc-linux-gnu/Color.o OBJ.i686-pc-linux-gnu/Draw_bitmap.o OBJ.i686-pc-linux-gnu/Draw_line.o OBJ.i686-pc-linux-gnu/Draw_point.o OBJ.i686-pc-linux-gnu/Get_w_box.o OBJ.i686-pc-linux-gnu/Get_w_line.o OBJ.i686-pc-linux-gnu/Get_w_pointer.o OBJ.i686-pc-linux-gnu/Graph_close.o OBJ.i686-pc-linux-gnu/Graph_set.o OBJ.i686-pc-linux-gnu/Line_width.o OBJ.i686-pc-linux-gnu/Panel.o OBJ.i686-pc-linux-gnu/Polydots.o OBJ.i686-pc-linux-gnu/Polygon.o OBJ.i686-pc-linux-gnu/Pol!
yl!
in!
I didn't use that.
to:
This helps.
Right, this indicates that I have circular dependencies which
could not be resolved due to the changes in libgrass_driver.
Above order modification is a way out.
library.
The problem is that I need them there to keep the grass-gdal plugin
running for Mapserver/GRASS-PHP.
But the LDFLAGS change should to the job, right?
I have applied it to CVS and launched the cron job to
create the binary snaphot (should be ready in 1h from now
if it completes now).
I didn't use that.
Something is adding an explicit -L/usr/local/lib. Could you see if
there's anything obvious in Platform.make?
In general, any directories which the linker searches automatically
shouldn't be specified explicitly, as that will get the ordering
wrong.
> library.
I was going to say "you only need the versioned names at run-time",
and then remembered that the GRASS libraries don't have versioned
names :frowning:
It should fix this specific issue. I'm just thinking in general terms.
