Good people,
i’m trying to figure out if GRASS can import netcdf format files.
Has anyone out there used netcdf files for modeling in GRASS?
thanks,
vishal
Good people,
thanks,
vishal
As far as I know NetCDF is not supported directly in GRASS. But there
are several good utilities (for example in Scientific Python) for
extracting the data layers from NetCDF that can then be reformatted
for use in GRASS.
David
On 2/28/06, Vishal Mehta <vishalm1975@gmail.com> wrote:
Good people,
i'm trying to figure out if GRASS can import netcdf format files.
thanks,
vishal
David Finlayson
U.S. Geological Survey
Coastal and Marine Geology
831-427-4757
831-427-4748 (fax)
USGS Pacific Science Center
400 Natural Bridges Drive
Santa Cruz, CA 95060
Vishal,
GDAL has limited support for the netcdf format
(http://www.gdal.org/frmt_various.html#netCDF). You have to compile
GDAL explicitly with this option since it's not the default. If you've
got his setup, you might be able to use r.in.gdal to import to GRASS.
matt
Good people,
thanks,
vishal
Matt Perry
perrygeo@gmail.com
http://www.perrygeo.net
