Daniel,
v.in.e00 is simply a shell script wrapper to avcimport.
So, avcimport is doing the job, then v.in.ogr is used.
So we hope for a avcimport fix
thanks for the quick response,
On Thu, Mar 02, 2006 at 05:04:03PM -0500, Daniel Morissette wrote:
It seems that your file suffers from the same empty text class name
problem that's described here:
http://bugzilla.maptools.org/show_bug.cgi?id=1261#c1
This is not fixed in the lib yet.
The simple work around is to add a
name (e.g. "somename") in the blank line that follows the TX7 line in
your file:
-----8<-----
TX7 2
somename
0 1 2 0 1 0 7
0
------>8----
I don't know if v.in.e00 should be affected by this issue, but the
"avcimport" program definitely is. I'd suggest that you try that first
and if you still don't get the label strings (names) then I may need
more details on how v.in.e00 handles label strings to give a more
meaningful answer.
Daniel
Markus Neteler wrote:
>Jason,
>I have tested the E00 file, in fact the names aren't transferred.
>To me it looks like an avcimport bug (http://avce00.maptools.org/avce00/)
>I cc to Daniel Morissette, the maintainer of the package.
>It doesn't look like a GRASS problem.
>Markus
>On Wed, Mar 01, 2006 at 09:03:50PM -0500, Jason Horn wrote:
>>Thanks guys. I've posted the e00 at:
>>http://www.109valentine.com/gis/pppoint.e00
>>This file is from http://data.geocomm.com/. Hope you have luck with it.
>>- Jason
>>On Mar 1, 2006, at 4:56 PM, Markus Neteler wrote:
>>>On Wed, Mar 01, 2006 at 10:25:41AM -0500, Jason Horn wrote:
>>>>I have a simple e00 coverage that contains points attributes (it's a
>>>>bunch of cities and towns along with their names) importing with
>>>>v.in.e00 get me the points, but the attributes(names) are missing. I
>>>>have also tried converting with avcimport first, then in through
>>>>v.in.ogr. Makes no difference. Does anyone know what the problem
>>>>might be?
>>>>Thanks...
>>>Jason,
>>>can you put the E00 somewhere to look at?
>>>Markus
Daniel Morissette
http://www.mapgears.com/
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
