Hello; a real noob question: once I have a map layer I want to keep/share, how do I copy it into the PERMANENT location? When I tried r.copy, I got an error that a file does not exist.
TIA
Michael
TIA
Michael
Try "g.copy from=map@mapset to=map" in the PERMANENT mapset. The to= option of
g.copy does not support @MAPSET, so you must run grass with the PERMANENT
mapset.
Huidae Cho
that a file does not exist.TIA
Michael
> that a file does not exist.Try "g.copy from=map@mapset to=map" in the PERMANENT mapset. The to= option of
mapset.
Note that you have to own the current mapset. So to start GRASS in the
PERMANENT mapset, you have to own it (or su/sudo to the user who owns
it).
If you don't the necessary privileges, other users can still access
your maps either by using the map@mapset notation, or by using
g.mapsets to add your mapset to their mapset search path. In either
case, they need the necessary filesystem permissions.
OK, that makes sense, but when I start in the PERMANENT mapset, I don't see any of the maps in my other mapset. Does that mean there's some kind of permission problem, or do I need to remember the names of the other maps, or ...
Thanks again,
Michael
mapset.Huidae Cho
TIA
Michael
"g.list type=rast mapset=other_mapset" will help you.
Huidae Cho
problem, or do I need to remember the names of the other maps, or ...Thanks again,
>of
>mapset.
>Huidae Cho
>>TIA
>>Michael
