[GRASSLIST:1073] V.DIGIT
I am trying to digitize lines on Grass using the v.digit command. Even
if I "click" several points it gives me an error when I quit :
"Only one point digitized - ignored"
I am running Grass5b8 on a Mandrake Linux 7.1 based machine.
Can anyone help me ?
Thanks in advance.
Ricardo Martins
PROCERGS
Brazil
Ricardo Wagner Martins wrote:
if I “click” several points it gives me an error when I quit :
“Only one point digitized - ignored”
Thanks in advance.
Ricardo Martins
PROCERGS
Brazil
In the Custimize menu you can set the digitizing /snapping threshold. Try to decrease it.
Ralf Kunkel
Dr. Ralf Kunkel
Programmgruppe Systemforschung und Technologsiche Entwicklung (STE)
Forschungszentrum Juelich GmbH
D 52425 Juelich
Tel:    ++49-2461 61 3262               Email: r.kunkel@fz-juelich.de
Fax:    ++49-2461 61 2540               WWW:    www.fz-juelich.de/STE
> Hi all,
> Thanks in advance.
> Ricardo Martins
> PROCERGS
> Brazil
to decrease it.
Hi Ricardo,
please don't forget to set the correct map scale in the map definition
sheet (when opening the vector map with v.digit). Otherwise you can't
set the digitizing /snapping threshold properly.
Regards
PS: Dr. Ralf Kunkel:
Not Found
The requested URL /STE was not found on this server.
