[GRASSLIST:10817] Re: Error in startup script: couldn't execute "ps.map": no such file or directory
Hello Ravi,
I installed grass-6.0.0 from source grass-6.0.0.tar.gz and not using rpm.
After i got errors i tried the following:
I copied the lib directory from grass-6.0.1 into grass-6.0.0 and then compiled it successful.
It worked fine with no errors.
But this definately isnt the solution.
May I know which RPMs are you referring to?
Nagesh Bhatkar
RAVI KUMAR wrote:
Hi Nagesh,
it is loading of RPMs that may not be ok..
Pl check.
Ravi Kumar
*/Nagesh Bhatkar <bnagesh@nio.org>/* wrote:
    Dear GRASS users,
    I Installed grass-6.0.0 on mandriva 2006.
    On running grass , I get the following error
    directory
    while executing
    "exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
    "DmPrint::init"
    (procedure "main" line 32)
    invoked from within
    "main $argc $argv"
    (file "/home/bnagesh/grass-6.0.0/etc/dm/d.m.tcl" line 894)
    After realising that ps.map isnt getting compiled , i tried
    compiling it
    manually
    using make command in the ps directory.
    I got the following error:
    /usr/bin/ld: cannot find -lgrass_I
    collect2: ld returned 1 exit status
    make[1]: ***
    [/home/bnagesh/grass-6.0.0/dist.i686-pc-linux-gnu/bin/ps.map] Error 1
    make[1]: Leaving directory `/home/bnagesh/grass-6.0.0/ps/ps.map'
    Later i realised that in ~/grass-6.0.0/lib, libgrass_I.so ,
    libgrass_Iortho.so, isnt created.
    Can anyone help me get rid of these errors.
    Has anybody compiled grass-6.0.0 on mandriva 2006 successfully?
    Kindly help
    Nagesh Bhatkar
    Project Assistant III
    National Institute of Oceanography
    India - Goa
Yahoo! Mail
Use Photomail <http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=38867/*http://photomail.mail.yahoo.com&gt; to share photos without annoying attachments.
