Hey there, Kirk:
I have tried several approaches. I started out by trying to compile from source by tracking down each component, installing, and then making sure everything worked together properly. Most of the components (gdal, R-language, tcl/tk, etc.) installed without a problem, but I ran into difficulties when I got to the point of installing GRASS itself and Postgresql. I ran around in circles for a little bit with this until I cam across Fink - the OS X package manager.
Once I had Fink and realized that there was an install of GRASS through it, I cleaned out my previous install attempt and tried to do it completely through Fink. At first glance, just about everything you need can be installed through Fink except a small handful of dependents like R-Language. However, I started running into a new problem where the GRASS and Postgresql .info files were not written correctly. Postgresql .info was looking for several things in the wrong places for OS X, though this was corrected with a new .info file last month. The GRASS .info file also had some code not quite right and no response from the maintainer of the file about when it would be updated.
I ran into a lot of problems with Postgresql, so I decided to try MySQL as the database. The MySQL install went smoothly, though I did start running into problems with getting GRASS to talk to MySQL properly. I am currently at the point where both GRASS and MySQL are installed, but I can't use GRASS yet because I haven't found the right approach to make them work together - GRASS can't use or write to the MySQL database folders yet.
I have done a decent amount of surfing on the web and it seems like all the working installations of GRASS are on Linux boxes. With each problem I had I found other people who had similar problems trying to install GRASS on OS X, which leads to a lack of confidence that this is an easy thing to do at this point.
There is always the option of OpenOSX's GRASS CD, but I don't currently have any money at work for purchasing software. NASA uses ESRI's ArcGIS as it's "official" GIS solution, but I have been trying to show that there is another option that would work just as well as ESRI without the ridiculous cost - another reason that I have been trying to install without paying for anything.
I *want* to use my Mac as my primary GIS application platform, but the only reason I am still beating my head against this wall is because I am just plain stubborn.
ESRI leaves me stranded on a Wintel machine, but the Mac is a better platform - if I could just get the damned software working correctly.
Overall, at this point in time, I wouldn't recommend relying on GRASS on a Mac as your GIS solution. Or if you do, also budget for OpenOSX's GRASS cd-rom as it does have a limited amount of technical support that may make the difference in getting everything working quickly. Maybe in another 6-12 months doing a self-install of GRASS will work better, but right now it is an uphill struggle.
Bill
Bill,
I find your email troubling in that I was about to purchase a new G5
with the intention of running grass. I am currently using a freebsd box,
but am in need of some faster hardware and more disk space. However,
before I run off and buy a g5, I'd like to think that the install would
go smoothly. Are you compiling grass from source or is there a binary
that you are trying to get installed?
If you get off list responses to your querry would you mind either
forwarding them to me or doing a summary (once you get grass running on
os x)? Thanks in advace...
Kirk
On Tue, 2003-09-02 at 09:23, Bill Dickinson Jr wrote:
Hey there:
I have been running in circles for about 2 months now trying to get
GRASS installed on my OS X box and have yet to get it successfully
running. If there is someone out there who has successfully installed
and is currently running GRASS on their Mac, and would have the time
> to talk me through yet another installation attempt, I would
appreciate the assist. My "friends" keep telling me to stop beating
my head against the OS X wall and simply use a Linux box, but being a
Mac-fanatic I would really like to have it working on my Mac.
Thanks.
Bill
Kirk R. Wythers Department of Forest Resources
Tel: 612.625.2261 University of Minnesota
Fax: 612.625.5212 1530 Cleveland Ave. N
Email: kwythers@umn.edu Saint Paul, MN 55108 USA
Bill Dickinson
GIS Specialist
NASA Goddard Space Flight Center
Environmental & Safety Branch, Code 250
wdickins@pop700.gsfc.nasa.gov
