I've made those changes in mid-February this year. Could you try running the
following code and let me know what this does? Don't worry, it's like "find
dir" command.
cc -o list list.c -Wall
./list /
---<list.c>---
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <dirent.h>
static int recursive_list(const char *path);
int
main(int argc, char *argv)
if(argv[1])
return recursive_list(argv[1]);
return 1;
static int
DIR *dirp;
struct dirent *dp;
struct stat sb;
char path2[1024];
if(lstat(path, &sb))
return 1;
if(!S_ISDIR(sb.st_mode))
printf("file: %s\n", path);
return 0;
if((dirp = opendir(path)) == NULL)
return 1;
while((dp = readdir(dirp)) != NULL)
if(dp->d_name[0] == '.')
continue;
sprintf(path2, "%s/%s", path, dp->d_name);
recursive_list(path2);
closedir(dirp);
printf(" dir: %s/\n", path);
return 0;
On Thu, Mar 09, 2006 at 08:33:26PM +1300, Hamish wrote:
Just a thought,
in the past weeks some code was changed to replace system calls with
their C equivalents. Maybe this has something to do with it. I can't
connect to the CVS-web interface currently to check.
Look for recent changes in:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/
Hamish
On Wed, 08 Mar 2006 21:04:54 -0600
Dave Kent <dkent@sasktel.net> wrote:
> Thanks for the insight. I went back to the Nov 05 binaries and
> Janurary CVS version and things work. That will be fine for now. I
> guess learning how to build wouldn't be a bad thing.
> Thanks for your help.
> Dave
> On Mar 8, 2006, at 6:40 PM, William Kyngesburye wrote:
> > This is probably the same bug Michael Barton reported yesterday
> > (#4152) and I reported last August (#3585). Specifically, when
> > GRASS is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
> > support. It's probably happening for you in Tiger because Lorenzo
> > builds with Panther compatibility - either on Panther, or on Tiger
> > using the Panther SDK. A Tiger-only build (GCC 4) is unaffected.
> > It's a strange bug - I can build GRASS with GDAL without Postgres
> > support, then update GDAL to include Postgres support and it still
> > works. It's only when GDAL has Postgres support *at the time GRASS
> > is built*. I've tried various combinations of static and dynamic
> > Postgres libraries (and the exact same ones used for Postgres
> > support in GRASS) and other options in GDAL and GRASS and GRASS
> > with/without its own Postgres support.
> > On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
> >> I am using Grass 6.1CVS on Macintosh with the most recent
> >> Macintosh binaries.
> >> g.remove gives the following error.
> >> child killed: bus error
> >> while executing
> >> "exec -- $cmd --tcltk"
> >> (procedure "execute" line 4)
> >> invoked from within
> >> "execute g.remove "
> >> (menu invoke)
> >> This started quite suddenly, possibly consistent with messing with
> >> AWK post I had yesterday.
> >> I get the same error with g.copy, g.rename but not g.list
> >> I have reinstalled the binaries and the application.
> >> There was a not too similar message in the archives which relates
> >> to the environmental variable file being corrupted. I cannot find
> >> this file and haven't tried removing it.
