I updated with the -dP option, but nothing changes.
Here's the output of make pre-install:
test -d /usr/local/grass-5.0b || mkdir -p -m 755 /usr/local/grass-5.0b
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
UNIX_BIN=/usr/local/bin SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION |
head -1 | sed 's/\..*//'` GISBASE=/usr/local/grass-5.0b MACHINENAME=`uname -n`
/bin/sh src/CMD/generic/CREATE_GMAKE.sh
cat: src/CMD/generic/../head/head.: No such file or directory
/bin/sh `pwd`/src/CMD/generic/is64bit.sh
cat: /usr/local/grass/src/CMD/generic/../head/head.: No such file or directory
/usr/local/grass/src/CMD/generic/is64bit.sh: 64test.c: command not found
/usr/local/grass/src/CMD/generic/is64bit.sh: ./a: No such file or directory
/usr/local/grass/src/CMD/generic/is64bit.sh: [: : integer expression expected
echo "Now proceed with make install"
No 'head.$ARCH' file is created, and it looks for a 'head.' file that
obviously doesn't exist either. There is a 'head' file in the src/CMD/head
directory (next to the 'head.in' file) with 'i586-linux-elf' as entry for the
ARCH variable.
Moritz
P.S. Markus : Entschuldige die Probleme mit meinem Mailprogramm. Ich bin
gerade auf exmh umgestiegen und habe noch einige Konfigurationsprobleme.
HI Moritz,
it must be a local problem, as many people can compile it. But: we will fix
it.
So: Did you update with "-dP" option?cvs update -dP
Then you get news directories also, if there.
P is removing empty directories.
Ah! Yes, the configure is generating head from
head.i. Then, if you say
make pre-install
you get the head.$ARCH file.Could you please try that?
Then make install should do the job.
Yours
On Sun, Nov 12, 2000 at 12:45:53AM +0100, Moritz Lennert wrote:
> Even when running ./configure again I get the same problem. I attached the
> config.log file in which there is an error message which might be linked to
> the problem. In the src/CMD/head directory I get a 'head' file and a 'head.in'
> file.
> I'm using Debian/Linux (Potato).
> > Hi Moritz,
> > On Sat, Nov 11, 2000 at 06:27:50PM +0100, mlennert@club.worldonline.be wrote:
> > > Hello,
> > > I have trouble compiling the cvs source tree. I get the following error
> > > message after typing 'make install':
> > ... here is the problem. ^^^^^
> > Recently we have updated the Makefile system to generate platform
> > specific file. Means: Formerly one head.file was generated.
> > Now you get a head file name depending on the computer platform
> > e.g. src/CMD/head/head.i686-pc-linux-gnu
> > After you have run
> > cvs update -dP
> > I guess you did not run
> > configure
> > again. If you do, the problem should be fixed as the new head-file
> > will be generated. Sorry for this inconvenience, but now you
> > can compile GRASS in a network of different platform types from
> > the same source code tree.
> > In case of "configure" does not fix your problem, please let
> > me know.
> > Kind regards
> > Markus
>Content-Description: config.log
> This file contains any messages produced by compilers while
> running configure, to aid debugging if configure makes a mistake.
> configure:571: checking host system type
> configure:594: checking for gcc
> configure:707: checking whether the C compiler (gcc ) works
> configure:723: gcc -o conftest conftest.c 1>&5
> configure:749: checking whether the C compiler (gcc ) is a cross-compiler
> configure:754: checking whether we are using GNU C
> configure:782: checking whether gcc accepts -g
> configure:815: checking whether ld -s works
> configure:827: gcc -o conftest -g -O2 -s conftest.c 1>&5
> configure:852: checking for a BSD compatible install
> configure:907: checking for flex
> configure:941: checking for yywrap in -lfl
> configure:985: checking for ranlib
> configure:1017: checking for env
> configure:1051: checking for f77
> configure:1081: checking how to run the C preprocessor
> configure:1165: checking for X
> configure:1479: checking for dnet_ntoa in -ldnet
> configure:1520: checking for dnet_ntoa in -ldnet_stub
> configure:1568: checking for gethostbyname
> configure:1666: checking for connect
> configure:1758: checking for remove
> configure:1850: checking for shmat
> configure:1951: checking for IceConnectionNumber in -lICE
> configure:1995: checking for ANSI C header files
> configure:2102: checking for curses.h
> configure:2102: checking for limits.h
> configure:2102: checking for termio.h
> configure:2102: checking for termios.h
> configure:2102: checking for unistd.h
> configure:2102: checking for values.h
> configure:2142: checking for sys/ioctl.h
> configure:2142: checking for sys/mtio.h
> configure:2142: checking for sys/resource.h
> configure:2142: checking for sys/time.h
> configure:2182: checking for sys/timeb.h
> configure:2182: checking for sys/types.h
> configure:2182: checking for sys/utsname.h
> configure:2219: checking whether time.h and sys/time.h may both be included
> configure:2254: checking for off_t
> configure:2287: checking for uid_t in sys/types.h
> configure:2322: checking curses.h WINDOW structure component
> configure:2335: gcc -c -g -O2 conftest.c 1>&5
> configure: In function `t':
> configure:2331: structure has no member named `maxy'
> configure: failed program was:
> #line 2325 "configure"
> #include "confdefs.h"
> #include <curses.h>
> WINDOW w;
> int main() {
> void t () { w.maxy = 0; }
> ; return 0; }
> configure:2354: gcc -c -g -O2 conftest.c 1>&5
> configure:2372: checking for ftime
> configure:2372: checking for gethostname
> configure:2372: checking for gettimeofday
> configure:2372: checking for lseek
> configure:2372: checking for nice
> configure:2372: checking for time
> configure:2372: checking for uname
> configure:2427: checking for seteuid
> configure:2427: checking for setpriority
> configure:2427: checking for setreuid
> configure:2427: checking for setruid
> configure:2480: checking whether setpgrp takes no argument
> configure:2535: checking for initscr in -lncurses
> configure:2577: checking for initscr in -lcurses
> configure:2595: checking for gtty in -lcompat
> configure:2640: checking for tgetent in -ltermlib
> configure:2685: checking for xdr_int in -lsun
> configure:2727: checking for xdr_int in -lnsl
> configure:2622: checking for gtty in -lcompat
> configure:2667: checking for tgetent in -ltermlib
> configure:2712: checking for xdr_int in -lsun
> configure:2754: checking for xdr_int in -lnsl--
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
