[GRASSLIST:1143] v.to.rast: problems with G_open_raster_new()
Hello,
I have imported some vector files *.e00 (which went
fine) and started the conversion to raster. I get the
following result:
GRASS:~ > v.to.rast streams out=streams2
Loading vector information ... 0 mins
00 secs
Sorting areas by size ... 0 areas 0 mins
00 secs
WARNING: G__open_raster_new: no temp files available
ERROR: Can't create raster map <streams2>
from running:
d.vect streams
d.region res=50 -pa
d.erase
Any ideas about why the G_open_raster_new cannot
function properly?
Thanks
Stef
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
following result:
00 secs
00 secs
from running:
d.vect streams
d.region res=50 -pa
d.erase
function properly?
The error message is potentially misleading, in that it seems to imply
that the problem is due to some sort of resource exhaustion. In fact,
that message is displayed if the temporary file could not be created
for any reason.
One possible reason is lack of disk space (either because the
partition is full, or because of quotas).
Another possible reason is that you don't have write permission for
the temporary directory. The temporary directory is the subdirectory
".tmp" within the mapset directory. Similarly, if the .tmp directory
doesn't exist, and you don't have write permission on the mapset
directory, attempting to create it will fail, and so creating the
temporary file will also fail.
In general, for any given location, each user should have their own
mapset directory (or directories); all files and subdirectories within
each mapset directory should be owned by (and writeable by) the owner
of the mapset directory.
