Hello all,
Looking at the manual page, I am confused about the following r.proj parameters:
input=name (Input raster map from source location.)
location=name (Source location of input map.)
I assume one parameter is the unix file path and one is the grass raster object name?
dbase=name (Database of input map)
Is dbase expected to be the unix path of the DB or just the DB name?
Sorry for such simple questions!!
TIA,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
On Mon, Nov 20, 2000 at 04:58:22PM -0800, Jeshua Lacock wrote:
Hello all,
parameters:
The simple name of the source raster in the other location.
Yes.
Also you may specify the mapset=<name> if it's possible you have the
same input raster name in different "mapsets" of the same "location"
(confused?).
raster object name?
If it's in a different GRASS database (yes, a directory path). This is
optional. For myself, I only use one GRASS database with several
locations/mapsets. Easiest that way. However, the data could be
located elsewhere in multiuser scenarios.
Eric G. Miller <egm2@jps.net>
