Folks,
I'm trying to construct an illustration that contains a large number of
lines (hydrologic features, roads and a rectangular grid for a ground
water model) overlain on a raster map showing results from the ground
water model.
Using ps.map from version 5, beta 7 I set the resolution of my postscript
device to 360 (supposedly, 360 dpi) and I specify that the vector files
should be plotted with a line width of 1 pixel. The line I get is several
times wider than the 0.003 inch (approximate) thickness that it should be.
I need very fine lines on this map or the lines obscure each other and the
model results.
Is there some other way to reduce this pixel size? I tried using
fractional pixel widths with no improvement. I also tried using the
"cwidth" specification in ps.map.new and found that the lines in the model
grid vector file were not categorized, which brings up an entirely
different question.
I constructed the file with the model grid from an imported ascii file and
no attributes file was created when the file was imported. I tried using
the bulk labeling option in v.digit to label the lines (there are over
13,000 lines, so manually labelling them would be inefficient at best),
but it doesn't work -- no errors are produced, but I get no labelled
lines. Is there some other way to label the lines? I program; if someone
can tell me how the lines are identified in the attribute files, then I
can construct the attribute file myself.
Roger Miller
