[GRASSLIST:1195] Re: [GRASS5] Re: notation standardisation
As a user issue, I like the way some command fields
can be shortened in the fashion of r.watershed. Saves
some typing at the command line...I would rather
things be consistent rather than short however.
--- "Eric G . Miller" <egm2@jps.net> wrote:
As follow-up, I also think we should use the same
parameter names used
by g.list, g.copy, g.remove, etc. when input/output
aren't appropriate.
So we have "rast", "vect", "sites", "icon",
"labels", "region", "group",
and "3dview" to use (and maybe "dspf" ?).
Rule of thumb [proposed]:
1. If the module takes a single input and produces a
single output, then
   use input=[name] and output=[name].
2. If the module just performs some action, but
doesn't produce an
   output different from the input, then use the
input "types" parameter
   "name" (i.e. "rast", "vect", etc...).
3. If the module has multiple inputs or outputs,
then attempt to use the
   parameter names above if possible, else parameter
names are left up
   to the author. So, If I had a module that took a
raster and a vector
   and produced a raster, it's parameters could be:
     r.something rast=[name] vect=[name]
output=[name]
   However, with some modules, there's more than one
input or output of
   a single "type", so then each name should be
descriptive of what its
   function is.
I don't know that we ever resolved the issue of
addressing sites
attributes. Basically we have something like:
   "east", "north", "dim", "cat", "decimal", and
"string";
for attribute names. For the "index", I don't know;
maybe just "index"
when there's only one to be specified, otherwise
"zindex" for "dim",
"dindex" for decimal and "sindex" for string??? I
know I'm guilty of
not being consistent here.
NOTE: I'd like to get some kind of simple attribute
database implemented
in GRASS, but so far I haven't found anything that
we could just plug in
with a few tweaks. The closest might be the Xbase
library, but it's C++
and I don't know how well Xbase files might support
efforts at
localization in the future. Anyway, I bring this
up, because
identifying attributes by "type" and "index" is
really cumbersome.
Eric G. Miller <egm2@jps.net>
David Finlayson
david_finlayson@yahoo.com
University of Washington
Box 351310
Seattle, WA 98195 - 1310
__________________________________________________
Do You Yahoo!?
Yahoo! Shopping - Thousands of Stores. Millions of Products.
http://shopping.yahoo.com/
subject 'unsubscribe grass5'
Hi David,
you don't have to specify full paramters. The minimum to
distinguish two similar parameters is sufficient.
