I installed the OpenOSX binary 5.0.2 posted on the GRASS site. After some tinkering, I got tcltkgrass running.
However NVIZ will not run, evidently on account of a missing library:
NVIZ exits with the error :
dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library: /usr/local/lib/libdl.1.dylib
(No such file or directory, errno = 2)
child killed: trace trap
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=AZero ve=Bathy -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
inspecting the files shows a libdl.0.dylib left over from my GRASS 5.0.0 OSX installation, but no libdl.1.dylib.
Is the NVIZ library not part of the binary distribution, and how can I fix this (without doing my own make). The libdl.1.dylib is also required for GDAL, so I cannot import using r.gdal until this is resolved.
I replaced the 5.0.2 etc/Nviz 2.2 folder with the Nviz 2.2 from the 5.0 distribution to make Nviz functional, what am i missing by using a old distribution version and what bug does this introduce (mixing version files)
The newbie question: can I simply add a binary of the missing library, and where can I obtain one.
Note also : the OpenOSX-tcltkgrass.diff patch reports an error (can't find file).
a file exist "tcltkgrass.tcl" in the /usr/local/grass5/tcltkgrass/main/ directory and a file tcltkgrass in the/grass5/ bin dirctory. The patch dialog seems to indicate the bin directory is the target ?
