[GRASSLIST:121] GRASS/postgresql
I am sorry that I have been such a source of annoying
inquiry today.
I found an answer to the GRASS/postgresql problem that I
just posted. (The binary of 5.0.2 wants libpq.so.2 and my
system has libpq.so.3 but not libpq.so.2)
The solution is based on the archived email reprinted below.
1. I made sure that /etc/ld.so.conf includes the nonstandard
location of the pgsql libraries: /usr/local/pgsql/lib and
that I had run ldconfig after making the addition.
2. I created a symbolic link link of /usr/local/pgsql/lib/libpq.so.2 for /usr/local/pgsql/lib/libpq.so, i.e
ln -s /usr/local/pgsql/lib/libpq.so /usr/local/pgsql/lib/libpq.so.2
which seems to have done the trick. (Please let me know if
there is anything dangerous about this "fix.")
Best,
Michael
    * To: grasslist@baylor.edu
    * Subject: [GRASSLIST:4846] odbc problem
    * Date: Sun, 27 Oct 2002 16:11:15 +0000
    * Sender: owner-GRASSLIST@baylor.edu
Hi everybody,
Thanks for replying me so numerously. When I executed the
"g.select.pg
database=database_name", I got the following message:
GRASS:~ > g.select.pg database=obc
g.select.pg: error while loading shared libraries: libpq.so:
cannot open
shared object file: No such file or directory
Even though I checked everywhere, I could not find the
missing library on my
computer. The description of the package
postgresql-libs-7.2.1-5.i386.rpm
states that it has it. ???
I found other libraries depending to the package in the
standard location
(/usr/lib). I solved the problem with duplicating libpq.so.2
and renaming it
to libpq.so. It worked.
Miha Staut
Michael Ash, Assistant Professor
  of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash@econs.umass.edu
http://people.umass.edu/maash
inquiry today.
If the major version is changed, it is done because the new version is
incompatible with previous versions in some regard.
However, the incompatibility might simply be due to the addition of
new features. In that case, programs which were built for the new
version won't work with the old version, but programs which were built
for the old version will work with the new version.
OTOH, it may be that existing functionality has been changed. In that
case, using the new version with a program which was built for the old
version will have unpredictable (and probably undesirable)
consequences *if* the program uses the functionality which has been
changed.
If the documentation doesn't explicitly state which of the above
situations is true, there isn't any way to tell.
