[GRASSLIST:1243] Re: possible bug?
-----Original Message-----
To: Deuchler, Christoph
Cc: 'GRASSLIST@baylor.edu'
Sent: 9/15/2003 1:42 PM
Subject: Re: [GRASSLIST:1234] possible bug?
If you delete the
ellps: sphere
line and add
a: 6370997
b: 6370997
or whatever radius you want, that should work.
I tried that, but GRASS doesn't accept it, the WGS84 ellipsoid is used
instead. I added a sphere in ellipse.table but this produces an error
message about a invalid line in the file. It seems to work with a "almost
sphere" (a-b difference 1m).
Thanks for the help
Christoph
>If you delete the
>ellps: sphere
>line and add
>a: 6370997
>b: 6370997
Yes I doubt it would work in 5.0.0, as there were some sphere-handling
changes introduced soon after that release and then I had to make a few
more changes to get a sphere working properly in 5.3.x (CVS HEAD). So it
would be good if you could try it and report any further problems. The sphere
support hasn't been very well tested at all. In particular problems with
individual modules that use the ellipsoid information (to calculate distances
etc.) but don't use the proj library functions would be interesting, as I
haven't tested any of those.
Paul
