[GRASSLIST:1252] Two more grass5b10 gnats
For your enjoyment ...
Running grass5 died (linux prompt) and was only fixed by editing
/usr/local/grass5/tcltkgrass/script/gis_set.tcl to comment out lines:
706 #if { [string compare -nocase $ver "8.0"] < 0} \
707 #{
708 # puts stderr "Sorry your version of Tcl/Tk is $ver and is too old for GRASS."
709 # puts stderr "GRASS requires a TCL/TK version of 8.0 or more."
710 # puts stderr "Reverting back to text mode interface."
711 # exit 1
712 #}
Yeah, I use vim. :^)
The error noted something along the lines of "string compare string1 string2"
as bring the correct syntax. Probably $ver is not getting filled somewhere
along the line.
Also.
When the GUI pops up, starting the monitor fails because my $PATH is too
long for it. Running d.mon from the grass5 prompt works fine. Perhaps
the Tcl/Tk should not worry so much about the size of environmental
variables. If that is possible ...
Hope this helps.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM, University of Minnesota
206 Church St. SE, Minneapolis, MN 55455
(612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
Ferventer Vestite
Hi Chris
707 #{
old for GRASS."
711 # exit 1
712 #}
Actually, a better fix is to simply delete the -nocase option (and
remove the comments :).
too long for it. Running d.mon from the grass5 prompt works fine.
Perhaps the Tcl/Tk should not worry so much about the size of
environmental variables. If that is possible ...
Hmmm. I'm not sure what the problem is here, I do not know of any limit
to the size of environment variables. What is the actual error message
you get?
Thanks for notifying us of these problems.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
