On Wed, Sep 17, 2003 at 10:16:47PM +0200, Markus Neteler wrote:
On Tue, Sep 16, 2003 at 03:02:31AM -0300, Jean Ferreira wrote:
> I try to use the function to r.binfer but I receive an error: Prior probabilities don't sum to 1.0 (found sum of 0.000000).
> I tested in these versions, using the conectiva linux 9.
> grass-5.0.2_src
> grass-5.0.3rc3_src
This is a known bug for a long time (unfortunately).
grateful for the tips and clarifications.
It includes in the Bugtracking system (request 2116), the report. Also I go to try to give one looked at in the code source.
thanks.
Bernhard Reiter escreveu:
grass-5.0.2_src
grass-5.0.3rc3_src
Jean, can you add a bug report to the tracker?
Jean Samarone Almeida Ferreira
jean@ucpel.tche.br
Ciência da Computação - UCPel
