I am trying to compile 5.0.2 under cygwin. Congigure fails while checking for location of GD includes: gd.h not found. Even if I configure with-gd=no.
Any suggestion?
Rich
Any suggestion?
Rich
configure with-gd=no.Any suggestion?
Did you spell the option correctly? There should be two leading
dashes, i.e. "--with-gd=no" or "--without-gd".
Glynn, et al;
Apologies for my dumb question. I was using a configure script as a template and adding my switches at the beginning of the list. I disabled GD at the beginning of the list, but there was a --with-gd=yes further down in the list.
Thank you for your help, sorry to waste your time.
Rich
> > > Any suggestion?
> Yes, I've tried both options, which result in the same problem.
> Interestingly, the configure says:
> checking whether to use GD... yes
> checking for location of GD includes...
> checking for gd.h... noDoes this only apply to --without-gd, or to all of the
--without-options?> Is it possible that I have some dependency that is causing this?
No; the --with-* options are never enabled or disabled automatically
by the configure tests.--
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
