[GRASSLIST:127] Creating vector from MySQL database (GRASS 6.1)
When I execute
v.in.db driver=mysql
database="host=ecolmod-mysql,dbname=renpatch_renosterbos"
table=def_renosterbos x=X y=Y z=RX key=_ID 'where=(_RUN = 5) AND
(_YEAR=99)' output=def_renosterbos_run_5_year_99_2
I get a Segmentation fault and an empty vector layer is created - am I doing something wrong or is it a bug?
Rainer
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation Biology (UCT)
Department of Conservation Ecology
University of Stellenbosch
Matieland 7602
South Africa
Hello Rainer,
On Wed, 15 Mar 2006 12:22:22 +0200 Rainer M Krug <rkrug@sun.ac.za>
wrote:
When I execute
Untested:
use your quotes slightly different:
table=def_renosterbos x=X y=Y z=RX key=_ID where="(_RUN = 5) AND
(_YEAR=99)" output=def_renosterbos_run_5_year_99_2
Perhaps this helps.
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Hello Rainer,
On Wed, 15 Mar 2006 13:51:25 +0200 Rainer M Krug <rkrug@sun.ac.za>
wrote:
Thanks, but Ho difference - empty vector layer and "Segmentation
fault"
Another thing I could imagine is the key-column beginning with an
underscore. Do you have the possibility to temporary create another
ID-column inside your data-table (perhaps use the OID-column if
present?) to see if that is a problem?
Best
  Stephan
Rainer
Stephan Holl wrote:
> Hello Rainer,
> wrote:
>> When I execute
> Untested:
> Perhaps this helps.
> Stephan
