[GRASSLIST:1273] Re: tcltk problem with grass5b10
I too had this same error upon installing under Linux
Mandrake 7.2. ./configure fails to find the tcl library
(tcltk 8.3 is included) for some reason. After manually
editing the resulting Gmakefile so that the library is
correctly identified, then the make install step does
work and the funny little box etc. go away. Perhaps
there's a way to fix the configure script so it finds
the library right in the future? This is beyond my
area of knowledge.
Bill B
-----Original Message-----
From: Justin Hickey [mailto:jhickey@hpcc.nectec.or.th]
Sent: Thursday, December 14, 2000 12:47 AM
To: Andy Bernat; grasslist@baylor.edu
Subject: [GRASSLIST:1268] Re: tcltk problem with grass5b10
Hi Andy
Andy Bernat wrote:
I just compiled grass5b10 using SuSE 7.0 (personal ed.). I got a
message that tcltk wasn't installed but because other applications
using tcltk work, I went ahead and tried loading grass. All I get is
a tcltk box with a title something like tkgis_set (not quite right but
close) but nothing in the box and there is no response when I click on
it. Is this a problem with my tcltk installation? I'm thinking not
because I let SuSE do it automatically and, more importantly, other
applications are having no problems with it. Or is it a problem with
my grass setup? I didn't set up any data directories because I
thought I'd be prompted to do so later but I can't get beyond this
little box. Thanks in advance for any help.
The fact that you have a Tcl/Tk box indicates that wish is running, so
the problem is not with Tcl/Tk, but somewhere else in the initialization
scripts. Were there any other error messages? Do you have a .grassrc5
file? If so, what are it's contents?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
area of knowledge.
Bill B
I have the same problem, but when I close the box I have a null
parameter error
in the Init.sh: GISDBASE not set.
Peter
area of knowledge.
Could you be so kind as to tell me what the paths are to
tk.h and tcl.h under /usr/include/?? and how the libraries are named on
Mandrake /usr/lib/libtk8.3.a ? You must have the static libraries for
configure to work.
Eric G. Miller <egm2@jps.net>
