[GRASSLIST:1277] Re: tcltk problem with grass5b10
I'm guessing that because the tcl script associated with
GRASS startup does not run properly that the .grassrc
file that is supposed to contain the GISDBASE info
simply doesn't get made right or read right. If you
fix the reference to the tcl library, then redo make
install, in my case this fixed it.
Bill B.
-----Original Message-----
Sent: Thursday, December 14, 2000 6:49 AM
To: grasslist@baylor.edu
Subject: [GRASSLIST:1274] Re: tcltk problem with grass5b10
"William L. Baker" wrote:
I too had this same error upon installing under Linux
Mandrake 7.2. ./configure fails to find the tcl library
(tcltk 8.3 is included) for some reason. After manually
editing the resulting Gmakefile so that the library is
correctly identified, then the make install step does
work and the funny little box etc. go away. Perhaps
there's a way to fix the configure script so it finds
the library right in the future? This is beyond my
area of knowledge.
Bill B
I have the same problem, but when I close the box I have a null
parameter error
in the Init.sh: GISDBASE not set.
Peter
