Hi Grass Users,
I have a raster map of a location. I have also a raster map showing the latitudes and longitudes in degrees.
Both of them are georeferenced. I want to combile both the raster maps so that I can get an image which shows both he location area
and the latitudes and longitudes marked on it. How to do it? Can any body help me.
Thanks.
uttam.
_________________________________________________________________
MSN Hotmail now on your Mobile phone. http://server1.msn.co.in/sp03/mobilesms/ Click here.
help me.
Use r.patch. This requires that the overlay map has nulls where it is
supposed to be transparent; if you are using any other value (e.g.
zero), you will need to change it to null using e.g. r.null.
