[GRASSLIST:1296] Bridge problem in 2D topological network
I was thinking about the difficulty in representing a bridge
in a 2D topological road network.
Could a "turns" attribute be the solution? This attribute would
indicate which turns are legal at each intersection. A bridge
would then be a standard + intersection, with each road
being restricted in it's "turns" to only the road directly
ahead.
nick
Opinions contained in this e-mail do not necessarily reflect
the opinions of the Queensland Department of Main Roads,
Queensland Transport or National Transport Secretariat, or
endorsed organisations utilising the same infrastructure.
If you have received this electronic mail message in error,
please immediately notify the sender and delete the message
from your computer.
On Friday 19 September 2003 03:03, nicholas.g.lawrence@mainroads.qld.gov.au wrote:
Lines may cross without intersection.
ahead.
Attribute of what?
To store such information you need a matrix for relation between all
roads in both directions, it is kind of application, not general GIS.
Radim
