[GRASSLIST:1307] Colormode problems on powerpc linux
Hi --
I'm not able to switch to colormode float on my GRASS setup, which is a
recent CVS build running under Yellow Dog Linux on an iMac DV (Rage 128
video card, using XFree86 4.0). Here's a relevant snippet from the
commands:
   GRASS 5.0beta10 > d.mon start=x0
   using default visual which is TrueColor
   Visual is read-only or using a private colormap
   ncolors: 32768
   allocating memory...
   Graphics driver [x0] started
   Mapset <allan> in Location <califutm10>
   GRASS 5.0beta10 > d.colormode mode=float
   Sorry, floating color table not available on this device
   GRASS 5.0beta10 >
Does anybody have any insights or fixes that will enable me to use a
floating color table?
Many thanks,
Allan D. Hollander
adh@ice.ucdavis.edu
On Tue, Dec 19, 2000 at 05:54:27PM -0800, Allan Hollander wrote:
Hi --
commands:
   ncolors: 32768
   GRASS 5.0beta10 >
Many thanks,
Allan D. Hollander
adh@ice.ucdavis.edu
Hi Allan,
as the GRASS 5 XDRIVER support much more colors than the old 4.x
Xdriver the d.colormode mode=float is not required any more. We
should consider to remove it (or improve the error message).
If you want more than 32768 colors, use the
    nlev Number of color levels for each R/G/B
option of d.mon.
Hope this helps
Markus Neteler
I don't think the number of color levels is the issue (I have no problem
with running under 24-bit color). Rather, d.colormode mode=float seems
still to be needed in order to adjust a color table interactively in
d.colors (i.e. highlighting a category, and having changes to the color
table appear immediately).
-- Allan
On Wed, 20 Dec 2000, Markus Neteler wrote:
Hi Allan,
option of d.mon.
Hope this helps
Markus Neteler
