one more problem for me..
When I compiled 5.0.2 on OS X 10.2.6 compilation failed for r.in.gdal and Nviz but it was ok for me then as I was needed at that time the the functionality of them...But now I need r.in.gdal. I downloaded the CVS version of it and tried to compile it with gmake5.I have libgdal1.1 installed in usr/local/lib
The following error occured:
[Edmund-Blackadders-Computer:src/raster/r.in.gdal] edmund% gmake5
SRC = /Users/edmund/grass5.0.2/src
CMD = /Users/edmund/grass5.0.2/src/CMD
UNUSED = /Users/edmund/grass5.0.2/unused
HEADER = head.powerpc-apple-darwin6.6
ARCH = powerpc-apple-darwin6.6
GISBASE = /Users/edmund/grass5.0.2/dist.powerpc-apple-darwin6.6
VERSION = 5.0.2 April 2003
/Users/edmund/grass5.0.2/src/raster/r.in.gdal
make -f OBJ.powerpc-apple-darwin6.6/make.rules
gcc -L/Users/edmund/grass5.0.2/src/libes/LIB.powerpc-apple-darwin6.6 -o /Users/edmund/grass5.0.2/dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal OBJ.powerpc-apple-darwin6.6/main.o OBJ.powerpc-apple-darwin6.6/gbgetsymbol.o OBJ.powerpc-apple-darwin6.6/gdalbridge.o OBJ.powerpc-apple-darwin6.6/make_loc.o \
-ldl -lproj -lgis -lintl -lI -lz
ld: Undefined symbols:
_GBGetSymbol
make: *** [/Users/edmund/grass5.0.2/dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal] Error 1
Then as I downloaded and installed the binaries but but r.in.gdal was exiting with error:
GRASS 5.0.2 > r.in.gdal
dyld: r.in.gdal can't open library: /usr/local/lib/libdl.1.dylib (No such file or directory, errno = 2)
Trace/BPT trap
I have the libdl.0 in usr/local/lib but not libdl.1.dylib
Any workarounds for both problems?
Thanks
Konstantinos Theofilis
-o
_GBGetSymbol
Either:
1. In src/raster/r.in.gdal/Gmakefile, change:
EXTRA_CFLAGS = $(GDAL_CFLAGS)
to:
EXTRA_CFLAGS = $(GDAL_CFLAGS) -D__unix
and re-compile.
2. Run "make clean", "configure --with-gdal ...", "make".
make: ***
r.in.gdal] Error 1
exiting with error:
Trace/BPT trap
The source for this library is available from:
http://www.opendarwin.org/projects/dlcompat/
See the thread entitled "GRASS 5.0.2 on Mac OSX and libdl.1.dylib" in
the list archives for more information on this subject.
