[GRASSLIST:1331] 5.7 cygwin Xlib.h
I am still trying to learn how to compile 5.1/5.7 under cygwin. I have 5.0.2 compiled successfully under my current cygwin configuration with some help from this list. I am using Markus's conf_grass51_cygwin.sh script as a template. I can get through configure, and make mix, but at make I get errors at:
gcc -I/home/Rich/grass57_exp_2003_09_20/include -/home/Rich/grass57_exp_2003_09
_20/dist.i686-pc-cygwin/include -I/usr/include/ncurses -I/usr/X11R6/include -O2
-D__W98__ -Wall -Wconversion -Wno-implicit-int -I/usr/include/ncurses -I/usr/X11R6/include -fPIC -I/home/Rich/grass57_exp_2003_09_20/include -I/home/Rich/grass57_exp_2003_09_20/dist.i686-pc-cygwin/include \
         -o OBJ.i686-pc-cygwin/open.o -c open.c
cc1: warning: -fPIC ignored for target (all code is position independent)
In file included from open.c:6:
/usr/local/include/tk.h:83:29: X11/Xlib.h: No such file or directory
/usr/local/include/tk.h:581: error: parse error before "Bool"
/usr/local/include/tk.h:583: error: parse error before "event"
Xlib.h does indeed seem to be missing from my system, but I am not able to find it via cygwin setup. Probably I am looking in the wrong place?
I have the precompiled X tcl/tk 8.x libraries and executables from http://grass.itc.it/grass5/binary/windows_cygnus/wingrass_xserver/ installed, not the "official" Cygwin Tcl/Tk package, as instructed at http://grass.itc.it/grass5/binary/windows_cygnus/cygwin_grass50bininstall.html
As always, thank you for your help,
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
I'm no expert, but I understand that the Standard Cygwin doesn't include
the XWindows server/code that's an additional download.
You should be able to find that on the Cygwin site.
Greg Ford
errors at:
You need to install the XFree86 packages.
