On Thursday 28 August 2003 04:20 pm, you wrote:
Keith J. Forbes wrote:
> I assume the fact that gdalinfo already works means that recompiling
> grass --with-gdal will not help, right? For the record, I have never
> before used the r.in.gdal module. I am sending this directly to you so
> that I do not offend the sender of the email.Keith,
If gdalinfo works, but r.in.gdal fails then one fairly likely possibility
is that the problem is with the way that r.in.gdal calls libgdal. The
default mechanism is a manual loading of the shared library by the
program code (my so called "bridging" approach). This may well be
broken now days and compiling --with-gdal will force r.in.gdal to actually
link against libgdal directly avoiding a bunch of possible errors.So, Paul may well be right, and if so I would appreciate hearing about it.
The other problem I saw but never completely verified was a user's whose
location was corrupt in some way, and r.in.gdal would core dump quite
early in the run. If that is the issue, you might want to try starting
a new location or something like that.By the way, since gdalinfo works, I would suggest you now try
gdal_translate:gdal_translate /path/to/directory out.tif
If that works then the problem is r.in.gdal specific for sure, and should
be submitted via the GRASS bug system if you can't work around it.
Unfortunately, it also means it is substantially less likely that I will
look into the problem since I don't have a working GRASS build at this
time.Best regards,
Hi. i thought I would quickly summarize what my problem was and how it was
solved so that others might benefit. Basically, when importing arc info grid
(not ascii grid) files using r.in.gdal i got segmentation fault errors. gdal
by itself worked fine on the grid files (I updated to GDAL 1.1.9.0, released
2003/06/27, but not sure if the update was bnecessary to fix the segmentaion
fault problem). The solution was to recompile grass5 linking directly with
gdal as follows:
./configure --with-postgres-includes=/usr/local/pgsql/include/ --with-gdal
--with-postgres-libs=/usr/local/pgsql/lib
(the postgres stuff is so grass5 links properly to postgres and has nothing to
do with gdal)
Thanks to Frank W. and Paul, and everyone else who responded, and to the Grass
developers and associated package developers for keeping this alive. Great
work guys.
Best,
Keith
k|J|f
