Dear GRASS users,
I wonder if someone can help us with our GRASS compilation on RedHat Linux.
The problem is that after running ./configure with option without-fftw,
make and make install, we can not go on with /usr/local/bin/gmake5 because
Gmakefile is not found. What did I do wrong?. Any clue?
Thanks in advance
Javier Álvarez Rodríguez
Centro de Estudios Hidrográficos del CEDEX
Paseo Bajo de la Virgen del Puerto, 3
28005 Madrid, España
javier.alvarez@cedex.es
+34 (91) 335 79 38
+34 (91) 335 79 22 (fax)
Have you run "make install" as root?
What version of RH and Grass have you?
-------spanish version
Hola
Uhmm, yo he compilado Grass5.0.2 en una RH7.3 y no me ha dado ningún
problema. No creo que sea por la opción de fftw, pero en último caso
tambien puedes probar a instalar ese programa y volver a compilar.
Espero haberte servido de alguna ayuda.
Javier Álvarez Rodríguez(javier.alvarez@cedex.es)@24.09.2003 08:55:49 +0000:
Dear GRASS users,
The problem is that after running ./configure with option –without-fftw,
Thanks in advance
+34 (91) 335 79 38
What exactly are you trying to do? You don't need to use "gmake5" when
compiling and installing GRASS normally; it's only required if you
wish to subsequently compile (or re-compile) specific parts of GRASS.
