Dear Sir Hamish, Ivan Marchesini
Thank you a lot lot times for your patience with my awkward questions.
Sorry that because of my poor English, my problem was not described clearly.
Actually, I just want to transform a scanned map into georeferenced XY
location map, and calculate a lakes area.
Thank GOD and your advice, eventually I got my i.rectified file.
I thought, may be, my problem was occurred because I did not gave i.rectify
enough time to transform data.
But except " You will receive mail when i.rectify is complete", i.rectify
did not give me any other message that it was completed the work or still
doing the work.
So I did not found my file, when i.rectify still doing on the work.
And may be there are other reasons which I couldn’t know.
Thank You for Your Help.
And please, I hope your more patience with me.
Sincerely
Ghalip Yasin
Tsukuba University, Japan
s01k154@shako.sk.tsukuba.ac.jp
Alle 05:52, domenica 28 settembre 2003, Alip.Yasin ha scritto:
Dear GRASS Users
Thank you very much for your help.
>>Are you looking in the LOCATION which was set with i.target? You'll
have
>>to exit GRASS from the XY location and restart in the target
(e.g.lat-lon) location.
Actually I did looked in the same location which I set in the i.target for
my i.rectified raster file.
r.in.gdal ( XY location)
-> i.group
-> i.target (the same XY location)
-> i.points
-> i.rectify -> " You wil receive mail when i.rectify is complete"
-> g.list (in the same XY location)
-> no raster file which I named during i.rectify
Are there the possibility that command i.rectify did not did the work?
Or it is not good to use the same location as the i.target location?
sincerely
Ghalip Yasin
Ivan Marchesini
University of Perugia
