> Hi, Can anybody tell me how I can get an ascii output of the x,y's
> in a vector file ordered sequentially. I have a vector file that
> contains the coast of Jamaica and I want this in a ascii file with
> x,y's ordered so that they follow each other around the coast.
> As it is now (v.out.ascii to xxxxx) the output formats all dump
> small line segments that are not sequential.
> Thanks (in anticipation).
v.build.polylines
A more complicated alternative which I used with great success before
finding v.build.polylines is with the join_cst matlab script, available here: http://sea-mat.whoi.edu/mapstuff-html/
(Octave should work if you don't have Matlab)
When I type r.report command to abtain an area data,
it gives me 0.623 km^2.
But I know this area was above 500 km^2.
Please tell me where is my problem are?
my steps doing this was:
1. make a UTM location and mapset
2. r.in.bin to import Landsat image.
3. r.digit to make an area which surrounds my area.
4. r.report
Thank you a lot.
Ghalip Yasin
Tsukuba University, Japan
s01k154@shako.sk.tsukuba.ac.jp
My obtained data (only one lake) through command r.report was still small
than real data.
Thank you to any of your advice.
> >3. r.digit to make an area which surroundes my target area(only one
lake).
> >4. r.report and obtained area data 0.623 km^2 <<<< the real area
500~700 km^2.
g.region rast=YourMap
r.report will only report on the current region (display monitor). For
the full map data you have to zoom to the extent of the map.
Ghalip Yasin
