Dear List,
I think I may be having the same problem as Andy Bernat ([1259] 13/12/2000)
but I can’t find a answer posted to his problem.
I have just loaded Grass5.0beta10 on my machine running Mandrake 7.0 with no
problems other than removing the -no case variable from the gis_set.tcl file
(Justin Hickey [1235] 8/12/2000). When I go to run GRASS I just get one
empty window with ‘gis_set.tcl’ in the title bar. All I can do with it is
close it which gives the following error message in the terminal window:
/usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set
I’m new to both GRASS and Linux so its likely to be a simple operator fault!
Thanks in anticipation.
Peter Brewer
University of Reading
UK
Get your FREE download of MSN Explorer at http://explorer.msn.com
Hi Peter
Peter Brewer wrote:
When I go to run GRASS I just get one empty window with 'gis_set.tcl'
in the title bar. All I can do with it is close it which gives the
I'm new to both GRASS and Linux so its likely to be a simple operator
fault!
The problem is that your $HOME/.grassrc5 file is corrupt. To fix this
simply delete the $HOME/.grassrc5 file and run grass5 again. This will
prompt you with the old text interface to set the location and mapset,
but the next time you run grass5, the interface will be TclTk. Please
let me know if you have any other problems starting Grass.
BTW, if you used the grass5 beta 10 sources then do NOT use any of the
"make clean" targets:
make mostlyclean
make clean
make distclean
make maintainer-clean
make savebinclean
They contain a serious bug that can delete system files not related to
Grass. If you installed the binaries though, you can ignore this
warning.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
