Hi !
I have some problems runnig r.wateshed on Grass5_beta10. It processed all the sections from 1a to 6 (closing maps) but then i receive an error message :
ERROR : G_malloc:out of memory
The Stream-segments raster has been created, but is empty.
The basins-label(ba) has been created and seams coherent.
I thought it was strange cause the work seams finished, but i must be wrong...
The raster elev is :
255 cat
Rows 3000
Colums 4000
Total cells : 12000000
Projection (x,y) with res=10 in x and y
R.watershed runs with t=1000000, ms=10000 all the ouput maps and no input exept the raster elev...
I have tried with t=10000 and ms=1000 with the same error and no map created.
All this run on an PII400Mhz, 128Mhz, HD 9Go SCSII, with mandake 7.1/Gnome
Would it be possible for r.watershed to tell the user if the amount of memory is usable with the parameters and the imput map BEFORE running ?
If someone has an advice...
Thanks !!!!
Yann
Yann Le Jeune
Laboratoire de Paleoenvironnement
Mission Archeologie
Conseil general de Seine-Saint-Denis
1 a 5 route de St Leu
93800 Epinay-sur-Seine
France
Get your small business started at Lycos Small Business at http://www.lycos.com/business/mail.html
