On Thu, Sep 25, 2003 at 11:42:34AM +0000, Miha STAUT wrote:
> Hi all,
> I tried to compile the grass57 source on my RedHat 7.3. However this is what
> happened while running make. I really am not an expert in compiling but
> would like to have the added power of grass57. Can anybody point me in the
> right direction.
> get_datum_name.c:33: conflicting types for `G_ask_datum_name'
> /home/src/grass57_exp_2003_09_13/include/gisdefs.h:530: previous declaration
> of `G_ask_datum_name'
> make[2]: *** [OBJ.i686-pc-linux-gnu/get_datum_name.o] Error 1
> make[2]: Leaving directory `/home/src/grass57_exp_2003_09_13/lib/gis'
> make[1]: *** [subdirs] Error 1
> make[1]: Leaving directory `/home/src/grass57_exp_2003_09_13/lib'
> make: *** [default] Error 1
> Thanks, Miha StautYou have to compile GRASS 5.7 with GRASS 5.3-cvs HEAD (not release branch,
not official version).
It is likely that the version of 5.3 you are linking into is outdated.
Both versions should be from the same week, preferably from
the same day (so
cvs up -dP
can update it for you) as they are kept in sync.Markus
Hi all and thanks to Hamish and Markus,
Eventually I managed to compile both the codes (grass50_exp and grass57). One error was reported at the end of make and seems to be related to the 3d modules (is that correct?):
GRASS GIS source code compiled.
Compilation error in module: src.contrib/GMSL/g3d (ignored)
* In case of errors please check following web page for hints:
http://grass.itc.it/grass5/source/compilation_hints.html
cp -f error.log error.log.i686-pc-linux-gnu
What I do not like is that non interactive version of g.region does not want to work due to problems with the PROJ library. I recently installed PROJ 4.4.7 and libproj.so.0 resides in /usr/local/lib. I also gave the --with-proj-libs at configure and it did not complain. But whenever I invoke the g.region command, it returns a message like this:
GRASS:/home > g.region -p
g.region: error while loading shared libraries: libproj.so.0: cannot open
shared object file: No such file or directory
This is true for GRASS 5.0 and for GRASS 5.7. There are also some other commands making the same problem (like v.in.gshhs and some ther).
I use the g.region command often and to manually set all the environment variables every time would be a time consuming process. What should I do?
Thanks, Miha Staut
_________________________________________________________________
Help STOP SPAM with the new MSN 8 and get 2 months FREE* http://join.msn.com/?page=features/junkmail
