On 3/15/06, David Finlayson <david.p.finlayson@gmail.com> wrote:
If you are using a database for your attributes can't you just run an
SQL query? Something along the lines of:
select first(CLASS) sum(SEG_LENGTH) from <table_name> group by CLASS;
On 3/15/06, Patton, Eric <epatton@nrcan.gc.ca> wrote:
> I have a vector of a coastline; the coast is segmented into different
> coastal types, according to unique IDs:
> CAT Class_ID CLASS SEG_LENGTH
> 1 5 Rock Cliff 56.789000
> 2 7 Barrier Beach 13.450000
> I successfully popluated the SEG_LENGTH column with the length of each
> segment using v.to.db:
> v.to.db Coastal_Classes option=length type=line units=m
> Now I want to report total lengths of each CLASS (i.e., total length of all
> "Rock Cliff" segments, etc.)
> Any ideas?
> ~ Eric.
In GRASS that would be something like this (note the comma I forgot in
last post):
echo "select first(CLASS), sum(SEG_LENGTH) from <table_name> group by
CLASS" | db.select
You pipe the query to your database through db.select. Alternatively,
if you are using a database like sqlite you can do the query right in
the database.
> > Any ideas?
> > ~ Eric.
> David Finlayson
of all "Rock Cliff" segments, etc.)
Any ideas?
maybe not the most efficient way, but:
v.extract out=rock_cliff where="CLASS = 'Rock Cliff'"
v.out.ascii.db rock_cliff column=SEG_LENGTH #from the wiki add-ons page
then add up in spreadsheet, matlab/octave, awk loop, etc.
Don't know of a UNIX command to do sums, but I'm sure there is one?
bc?
Note coastline length is a fractal problem and answers are only useful
when compared against the same dataset, e.g. as a percentage of the
whole. Even then trusting it is a bit dubious (same digitizer at the
same level of fatigue, etc).
> Any ideas?
bc?
___________________________________________________________
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
