[GRASSLIST:1396] postgreSQL problem
Hi GRASS users,
               I have downloaded the postgreSQL-7.3.4. I unzipped it and then went to the same dir of the postgresql and then installed it as follows:
1.) ./configure --prefix=/home/grass0pre3/psql --bindir=/home/grass0pre3/bin --without-readline
2.) gmake
3.) gmake check
4.) gmake install-all-headers
5.) gmake distclean
Then I wrote the following line in /etc/ldconfig "/home/grass0pre3/psql/lib" for the shared libraries.
Then I created a database and initialized it
root# mkdir /home/grass0pre3/psqldata
root# chown grass0pre3 /home/grass0pre3/psqldata
root# su grass0pre3
grass0pre3$ initdb -D /home/grass0pre3/psqldata
Lastly I started the server with
/home/grass0pre3/bin/postmaster -i -p 5432 -D /home/grass0pre3/psqldata >logfile 2>&1 &
Now when I run
createdb abc
and then
g.select.pg database=abc
I get the following error...
Error: select Postgres:could not connect to server: Connection refused
        Is the server running on host localhost and accepting
        TCP/IP connections on port 5432?
an any body tell me the problem and its related solution or have I missed anything during installation.
uttam.
_________________________________________________________________
Three simple steps. They guarantee your safety. http://server1.msn.co.in/features/general/SMBvirus/index.asp Protect yourself against the SMB.EXE virus.
* giovedì 02 ottobre 2003, alle 19:06, Uttam Kumar scrive:
Hi GRASS users,
follows:
2.) gmake
3.) gmake check
5.) gmake distclean
root# su grass0pre3
>logfile 2>&1 &
Now when I run
createdb abc
and then
It typically seems a problem concerning postgres not accepting
connections on the 5432 socket.
I suggest a few things:
a) go and set the tcpip_socket value to 1 (not 0) in the postgresql.conf
file (do a find to see where it is or try with "whereis
postgresql.conf";
b) edit the pg_hba.conf file (should be in the same dir) and make sure
you have something like this:
local all ident
sameuser
host all 127.0.0.1 255.0.0.0 ident
sameuser
host all 0.0.0.0 0.0.0.0 reject
host all 192.168.0.3 255.255.255.0 ident sameuser
in it.
It should do the game :slight_smile:
Bye
Dear GRASS Users
I downloaded some AVHRR files from <NOAA Satellite & Information>,
(some thing like this A3164585.L4908097).
For import these files into GRASS, I learned that < r.in.bin> can do this
work.
But I didn't find any infromation for <r.in.bin>s Parameteres
(north,south,east, west,r,c)
from my downloaded AVHRR files.
How could I import AVHRR into GRASS?
Eager for any help.
Heartfully Thanks.
Ghalip Yasin
Tsukuba University, Japan
You might try r.in.gdal, see:
http://grass.ibiblio.org/gdp/html_grass5/html/r.in.gdal.html
http://www.remotesensing.org/gdal/frmt_l1b.html
Hamish
Dear Hamish,
Thank you too much.
I tried command r.in.gdal input=A3164585.L4908097 output=name, but it said:
ERROR4: 'A3164585.L4908097' not recognised as a supported file format.
[ I am using GRASS 5.0.2 (Aprial 2003). ]
Ghalip
  > I downloaded some AVHRR files from <NOAA Satellite & Information>,
  > (some thing like this A3164585.L4908097).
  > How could I import AVHRR into GRASS?
On Sat, Oct 04, 2003 at 04:54:03PM +0900, Alip.Yasin wrote:
Thank you too much.
Looks like you have outdated GDAL. Please, run `gdalinfo --formats'
command and check whether the output contains a line for
`L1B: NOAA Polar Orbiter Level 1b Data Set'. If so and you still get an
error when reading your dataset, you should report this problem
via Bugzilla
http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
Hi all
I'm also working with AVHRR images but I'm importing
them in a different software because when I first
started working with them, GDAL would import but would
not do the automatic georreferencing. Does GDAL do
that now?
Thanks
Daniel
wrote:
> Thank you too much.
for
this problem
via Bugzilla
Andrey V. Kiselev
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
that now?
GDAL can read control points stored in every AVHRR file and you can
georeference the image using them.
          Andrey
Andrey V. Kiselev
> that now?
To my experience the polynomial rectification provided by GDAL is not
appropriate to achieve high precision geocoding (same as i.rectify).
I got shifts of up to 25km, implementation of local splines or similar
will be required (welcome also for i.rectify).
Dear Andrey Kiselev
I tried <gdalinfo --formats> and I have GDAL supported file name <L1B: NOAA
Polar Orbiter Level 1b Data Set> listed there.
But still r.in.gdal gives me "not supported file" error.
I will try to use Bugzilla to report this problem.
Thank you all for your help to me.
Thank you a lot.
Sincerely
Ghalip Yasin
Tsukuba University,Japan
  > Thank you too much.
  > I tried command r.in.gdal input=A3164585.L4908097 output=name, but it
said:
  > ERROR4: 'A3164585.L4908097' not recognised as a supported file format.
  via Bugzilla
  Andrey V. Kiselev
On Mon, Oct 06, 2003 at 02:37:46AM +0900, Alip.Yasin wrote:
Dear Andrey Kiselev
There is probably a local copy of libgdal within your GRASS installation
which is used by r.in.gdal instead of the system-wide installed library.
Thank you a lot.
Sincerely
Ghalip Yasin
  via Bugzilla
  Andrey V. Kiselev
Dear Mr.Markus Neteler
Thank you very much for your advice.
        >>There is probably a local copy of libgdal within your GRASS
installation
        >>which is used by r.in.gdal instead of the system-wide installed
library.
But sorry for my one after one foolish questions.
On this case, I don't know what I should do for solve this problem.
Could you please tell me further, how could I solve this problem?
Thank you, heartfully thank you for your patiently help.
Sincerely
Ghalip Yasin
installation
library.
Check if
/usr/local/grass5/lib/
contains a libgdal. If libgdal in /usr/local/lib is more recent,
replace
/usr/local/grass5/lib/libgdal... by a link to /usr/local/lib/libgdal...
Regards
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
