[GRASSLIST:140] Question about re-projecting points imported from Postgres
List:
I have a Lat-Long location into which I have successfully imported points from Postgres (a further question about this further below). What I want to do is to re-project the points into a Lambert Conic Conformal location using v.proj. When I try to do this, it does not work — it seems as though GRASS does not know how to do this. I have been able to do this successfully with points imported using v.in.ascii. It seems I am missing something, either conceptually or procedurally…
The further question about using v.in.db, the 'key' parameter in the documentation claims this is a string, which makes since to me, but when v.in.db is run, GRASS complains that an integer is needed. I'm guessing the integer that's supplied is the column/field number (beginning with '1'); if true, this seems to be inconsistent by what the 'x', 'y', and 'z' fields require — just a thought.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
Have you already created your Lambert Conformal Conic location? If
not, remember that v.proj pulls data into the current location from
somewhere else, projecting the data in the process if necessary.
On 3/15/06, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
David,
Yes, I had the LCC location created already. I've gone through this process many times, but never from data brought into GRASS via Postgres. Can it be that I missed a step after I imported the data using v.in.db into my lat-long location?
Tom
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
Ah, I understand now. I'm afraid I can't help you with this. I've only
used databases to hold attribute information not the topology also. I
haven't tried PostGIS yet.
David
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
David,
Maybe you don't understand. The Postgres table is for points and has the lat-long location; using v.in.db one is required to identify the x,y location. The additional attributes are read as well, of course. I can successfully import the Postgres table into GRASS into my lat-long location. If I then try to re-project the points into a LCC projection (from the LCC location), the v.proj does not seem to work. Is this what you previously understood I was tying to do or do now?
Who would know whether or not this can be done?
Thanks for you r responses…
Tom
David
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
If I understand you correctly, you have a table in Postgres that
happens to contain x, y coordinates in addition to other attributes
but is not a PostGIS layer. You were able to convert the X,Y points
into a GRASS vector file (points) using v.in.db AND this new vector
file seems to work in the lat long Location.
Now when you try to project the new vector file into a LCC location it
fails. What is the error you are getting? That seems like it should
work.
As a test, have you tried exporting the postgres table as a csv file
(at least pointid, x and y) and then load the vector with v.in.ascii?
You will be able to link the ID, X,Y CSV file back to the original
postgres attribute table using the ID column. Does this simple vector
file project?
David
On 3/16/06, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
David,
Tom
> David
>> List:
>> Tom
>> Thomas E Adams
>> VOICE: 937-383-0528
>> FAX: 937-383-0033
> David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
David,
You are correct in your understanding. Here is the error I'm getting:
v.proj input=locations location=ohrfc mapset=tea dbase=/grass/data output=locations
Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257223563 +no_defs
Input Unit Factor: 1
Output Projection Parameters: +proj=lcc +lat_0=39.0000000000 +lat_1=60.0000000000 +lat_2=30.0000000000 +lon_0=-86.0000000000 +x_0=0.0000000000 +y_0=0.0000000000 +a=6378137 +rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Creating vector file...
DBMI-Postgres driver error:
Cannot select:
select * from locations where 0 = 1
ERROR: relation "locations" does not exist
GRASS_INFO_WARNING(15679,1): Cannot open select cursor: 'select * from locations where 0 = 1'
Looking at this more closely, I think the problem may stem from the issue I describe earlier, namely:
In order to get the Postgres table to import into my lat-long location, I put a "1" in the field for the "category column name (string required)"; when I put "lid" in the field, I got an error saying the type was not an integer. It seems GRASS is expecting a string for the field name that has integer as its type. My problem is that none of my fields meet this requirement for the key field, the only column that does, "lid", has type string. So, I think what is happening is that when I try to use v.proj, I get:
Furthermore, when I use the query tool for the points in my lat-long location — while the x,y,z data is correct — all the other category data is the same — for record 1 in my Postgres table.
How do I get around the fact that my database table in Postgres does not have an integer field of unique values? A better question is why does GRASS require the key field to have type integer, when *really* the uniquely identifying field is the ID for a point (for instance).
Tom
work.
file project?
David
David,
Tom
David
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David,
I finally have reached some resolution on this, albeit maybe somewhat unsatisfactory…
Your suggestion to export to a CSV file and re-import worked, but not with the GRASS 6.1CVS version dated 03March2006. That is, v.in.ascii failed to import this data; however, using the GRASS 6.0.2 stable version worked. In fact, re-projecting the data I imported from Postgres into my LCC location from my lat-long location worked perfectly with GRASS 6.0.2, but I could not get the GRASS 6.1CVS version dated 03March2006 to do this.
I hate doing this, because there are many GOOD things with GRASS 6.1, but I am having to drop back to GRASS 6.0.2 for many of my applications. I must be able to import lat-long point data and re-project it into a LCC location.
Thanks for your help!
Tom
work.
file project?
David
David,
Tom
David
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
I've use v.in.ascii on text files almost daily and have not
experienced problems like you describe. If you can isolate the
problem, the developers would probably be very likely to fix the bug.
This is an important module.
As an aside, I use sqlite for my attributes, not Postgres and that may
be the difference between our experiences (though Postgres seems to be
the "preferred" database back end for GRASS)
David
work.
file project?
David
> David,
> Tom
> > David
> >> List:
> >> Tom
> >> Thomas E Adams
> >> VOICE: 937-383-0528
> >> FAX: 937-383-0033
> > David Finlayson
> Thomas E Adams
> VOICE: 937-383-0528
> FAX: 937-383-0033
David Finlayson
David Finlayson
David,
Very interesting. Here are the facts:
Using a RedHat Linux system
Both v.in.ascii and v.proj (from lat-long location to LCC location) work fine with GRASS 6.0.2 built from source.
Using GRASS 6.1CVS (dated 2006-03-18) built from source v.proj (now) works, but did not with the 2006-03-04 CVS build; v.in.ascii does NOT work -- I get errors:
WARNING: Unparsable LatLong value found:
         -80.04916667|39.56444444|860|49450586
         -84.82388889|38.705|0|49450588
         -88.50583333|39.35944444|0|49450598
         -81.20388889|39.56305556|0|49450600
         -82.17777778|41.34416667|0|49450616
         -84.95972222|39.73305556|0|113805417
         -82.92166667|40.35666667|901|113805418
         -85.15833333|39.57361111|850|113805424
         -80.64666667|37.72777778|1600|113805425
My ascii data file looks like:
-85.71666667|35.43166667|0|113805426
-86.38055556|36.89527778|500|113805427
-81.24583333|37.49416667|3100|113805430
-83.63833333|40.65805556|997|113805432
-81.71027778|38.18055556|622|113805434
-85.04916667|41.36|861.7|49460912
-85.67944444|40.30833333|880|113805437
-80.76166667|37.475|2159|113805438
The GRASS 6.0.2 interface generated v.in.ascii command with output looks like:
v.in.ascii input=/home/adams/locations.txt output=locs_new format=point fs=| 'columns=x double precision,y double precision,z double precision,id int' x=1 y=2 z=3 cat=0
Maximum input row length: 42
Maximum number of columns: 4
Minimum number of columns: 4
column: 1 type: double
column: 2 type: double
column: 3 type: double
column: 4 type: integer
Building topology ...egistering lines: 1000 2000 3000 4000 5000
5030 primitives registered Building areas:
0 areas built 0 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 4468
Number of primitives: 5030
Number of points : 5030
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
The GRASS 6.1CVS interface generated v.in.ascii command with output (not including the warnings/errors, above) looks like:
v.in.ascii input=/home/adams/locations.txt output=locs_new format=point fs=| skip=0 'columns=x double precision,y double precision,z double precision,id int' x=1 y=2 z=3 cat=0
That is, the comand never appears to complete...
Tom
David
work.
file project?
David
David,
Tom
David
List:
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
I had the identical thing happen the other day using 6.1 from 11 March.
I went ahead and put it into dbf format and imported it that way, but it
should have worked through v.in.ascii.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Fri, 24 Mar 2006 15:25:28 -0500
To: David Finlayson <david.p.finlayson@gmail.com>
Cc: GRASSLIST <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:372] GRASS 6.1CVS v.in.ascii problem
David,
like:
Building areas:
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Number of areas : 0
Number of isles : 0
Tom
David
work.
file project?
David
David,
Thanks for you r responsesŠ
Tom
David
List:
location using v.proj. When I try to do this, it does not work ‹ it
am missing something, either conceptually or procedurallyŠ
'z' fields require ‹ just a thought.
Tom
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
David Finlayson
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
I have debugged that and fixed a wrong memory free (wrong
position, I think) in CVS.
At least the pisted example now works for me.
Please try again,
PS: It must have been there for long time according to ChangeLog.
Maybe you just didn't use LatLong? It apparently only happened
in LatLong.
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Thomas Adams <Thomas.Adams@noaa.gov>
> David,
> like:
> Building areas:
> 0 areas built
> 0 isles built
> Attaching islands:
> Topology was built.
> Number of lines : 0
> Number of areas : 0
> Number of isles : 0
> Tom
>> David
>>> work.
>>> file project?
>>> David
>>>> David,
>>>> Tom
>>>>> David
>>>>>> List:
>>>>>> Tom
>>>>>> Thomas E Adams
>>>>>> VOICE: 937-383-0528
>>>>>> FAX: 937-383-0033
>>>>> David Finlayson
>>>> Thomas E Adams
>>>> VOICE: 937-383-0528
>>>> FAX: 937-383-0033
>>> David Finlayson
>> David Finlayson
> Thomas E Adams
> VOICE: 937-383-0528
> FAX: 937-383-0033
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
