Hi every body, I want to create a mapset from a scanned map. I allready
created the location and mapset with the 'xy' coordinate system, and
then tried tu run r.in.tiff (it is a tif image). But all I get is a
black display, even though I can see the created raster file in list of
rasters. After that, I did run r.support, but have to confess didn't
really know what I was doing... and I still see the black display. Can
any body advice me which other command I should use or what I am doing
wrong? I am not shure about the image, I guess it is not a geotif and
just a palin tiff.
In advance thanks a lot
Petra
just a palin tiff.
Try using r.in.gdal -oe instead of r.in.tiff The set your region to your imported tiff with g.region rast=imported_tiff.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
just a palin tiff.
If you're working in an X-Y location, it shouldn't matter if the image
is georeferenced.
Compare the region from "r.info <map name>" and "g.region -p".
Or just use "g.region rast=<map name>" to force the current region to
match the bounds of the map. If you still get an all-black map, check
the range of the data (again, with r.info).
