[GRASSLIST:1433] Beta10 startup
I have run into a problem starting GRass5.0Beta_linux.tar.gz
I am currently runmning Red Hat 6.2 and using Gnome.
Upon startup, I recieve the same message that was discuused in Decmeber
with the Libcurses.so.5 directory not being found.
I have installed that Linux RPM and I stilll have the problem.
One erson has responded by indicating that the libcurses library needs
to be linked.
I am lost, any suggestions to solve this problem
Kirk Schmidt
to be linked.
Kirk,
check your Linux CDROMs for the "ncurses 5" library. Install it and enjoy
GRASS. I am wondering that ncurses was not installed by default...
Hope this helps
Markus Neteler
Just an update for the record.
I verified that ncurses.so.5 was installed on my system, I checked in the
usr/lib/ directory and a file called libncurses.so.4.0 was present. I
copied the file and called it libncurses .so.5 and my problems were solved.
Kirk
> to be linked.
Kirk,
Hope this helps
Markus Neteler
  I have a similar problem, but it has so far resisted a solution. My RH 6.2
system (actually 6.1 with all the packages upgraded to the latest and
greatest) has libncurses.so.4 installed (plus the old glibc5 versions of 3
and 1.x). But, when I try to install ncurses-5.2-5.i386.rpm, I cannot.
  If I use the upgrade (-U) option, I'm told that too many apps require the
.4 version. So, I tried the install option (-i) to add the new version, too.
That failed because of conflicts with a version (ncurses-5.0-2) that cannot
be found in any form on my system.
  I know this is a linux problem, not a GRASS problem, and I've asked for
help from the local users group. My frustration is that it should be a
no-brainer to add a new version of the ncurses library without removing the
older version. Turns out to be a major project. Sigh.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
It sounds like an RPM problem rather than an actual linux problem.
Ignoring probable problems with version compatibility, you could just
create a softlink to libncurses4.0 and call it libncurses5.0.
Alternatively you could find the binary in a non-RPM package and install
it where it needs to be, or you could get the source package, compile it
and install it where it needs to be.
Personally I try to get everything as source code and compile if for my
system because in the past I frequently lost capabilities and had minor
incompatibilities in pre-compiled binaries. Things *are* improving now
and I doubt those problems are as common as they once were.
Roger Miller
Lee Wilson and Associates
Have you tried just making a link (ln -s) from your old library file to
the file name that your application (GRASS) wants?
Peter Earle
Biology Department
Memorial University
St. John's, NF
Canada
A1B 3X9
Rich
Peter,
  No, I didn't. Perhaps I'm wrong, but I assume that the newer version of
the library has changes that the GRASS-beta-11.2 requires.
Thanks for the idea,
Rich
  Thanks, Roger. I've had a number of SysAdmins here tell me that they
always get the source package and rebuild it on their systems. I'm trying to
be lazy because I have too much to do as it is. However, this appears to be
the most parsimonious solution.
  I shall go forth and hunt down the .src.rpm and rebuild it in house.
Rich
Peter,
Rich,
the libncurses5 is the same since month. I build the linux binaries
of GRASS-beta-11.2 on the same linux box as GRASS-beta-11.1 as
GRASS-beta-10 (maybe GRASS-beta-9 as well). So there was no change
in libncurses as far as I can remember (ah yes, installed 30. Jul 2000).
Simply get the ncurses5.rpm and feel happy...
http://rpmfind.net/linux/rpm2html/search.php?query=ncurses
