If the answer to this question is in a man page or other document, please
point me to it because I did not find the answer when I searched for it.
I have data produced by surveyors that I need to get into GRASS. In the
US, at least, surveyors work in their own, local coordinates rather than in
georeferenced coordinates. This means that they will find a section corner
monument in the ground, then run their survey from that point using metes
and bounds (or, angles and distances). This is how land documents are
legally described in this country. Even though surveyors now have access to
real time, kinetic, differential GPS that permits them to survey quickly and
to 1-2 cm accuracy, many still plot their maps as azimuth and distance from
a known point.
How can I translate these local coordinates to a standard
projection/coordinate/datum system (e.g., State Plane Coordinates, NAD83)?
If this is not currently available, is there anyone willing to work with me
on quickly producing a conversion filter? I have a new project that requires
this.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
a known point.
this.
I've thought about this before... I don't get data from surveyors so I
don't know the format(s). However, if you can translate everything to
points in space (rather than bearing/azimuth) than I think maybe
v.transform would be sufficient. I don't imagine most survey data
is for very large areas, so things like the curvature of the earth can
probably be ignored.
If there's some kind of way to tag the reference points to real world
coordinates from whatever file formats are provided, then I'm sure a
script could be worked up to build a vector line layer.
Eric G. Miller <egm2@jps.net>
On Sat, 10 Feb 2001, Eric G . Miller wrote:
However, if you can translate everything to points in space (rather than
bearing/azimuth) than I think maybe v.transform would be sufficient.
Eric,
These two sentences frame the problem exactly: translating a distance and
direction from a known georeferenced point to another georeferenced point.
Then taking the distance/bearing to the next point and georeferencing that.
Sure, once all the nodes are georeferenced the rest is easy. But, it's the
georeferencing step to which I referred. I infer from your answer that no
one on the list has looked into this. Guess it's research time for ol' Rich
in the Land of Geodesy.
Rich
Eric,
Just need to know the starting point (or some point) I think (possibly a
benchmark in some real coordinate system). Then everything else can be
calculated.
If it's lat/lon than there are library routines that could be used...
